Thomas Borchert writes:
Ok, you got me curious. No default position in all Cessnas I have flown. Both neutral and default positions were mentioned. While there is no default position, there is most definitely a neutral position, wherein the trim tab is aligned with the control surface, so that it creates no deflecting force. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Anno v. Heimburg wrote:
Okay, now that I've made the mistake of reading this discussion, you've got me curious: How does your plane's trim work? It's obviously not a trim tab. And how can there be no neutral/default position of the elevator or the trim device? It's the common anti-servo tab across entire trailing edge of the elevator. The trim tab position indicator is marked only as to a "takeoff" setting, which is roughly in the center. There is a sweet spot for aerodynamicists where all three horiz flying surfaces are in trail, not marked on the indicator, and it is forward of "takeoff," well toward nose down. A logical way to set tail incidence is so everything is in trail at 75% cruise velocity in std atmosphere at the alt where you can have the best cruise book number (marketing, really). As long as you still comply with Part 23 re trim effects. In MSFS, the indicator has a center mark, an apparent "default". In a typical real airplane, this ain't cruise. Where MX is getting all screwed up besides not understanding the the lift/drag effects of trim (it's almost a whole chapter in Dr. S. Hoerner's classic text, Fluid Dynamic Lift), is assuming MSFS knows when all surfaces are in trail. Such a tiny flight model tweak would be bizarre for a game sim which doesn't even fully understand air density. All trim essentially does in MSFS is tweak the same variable as elevator to allow for centering springs in joysticks. I've removed the springs from some of my joysticks, because then one fiddles less if at all with trim, and it can make hand flying even the jets easier. Much less unrealistic phugoid chasing. F-- |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Pocket PC Weight and Balance Spreadsheet | Navzilla Support | Piloting | 0 | October 9th 05 11:47 PM |
Cessna 172 F Weight and Balance | [email protected] | Owning | 8 | September 22nd 05 02:38 AM |
172S Weight and Balance Question | David J | Piloting | 9 | March 23rd 04 01:08 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
