Procedure for calculating weight and balance
Old January 9th 07, 01:31 AM posted to rec.aviation.piloting
Orval Fairbairn
Default Procedure for calculating weight and balance
Mxsmanic wrote:
Newps writes:
What's the neutral position of a Cub or Cessna 180?
I don't know. I've never flown anything that tiny.
Nor that big, either, for that matter!
  #132
Old January 9th 07, 02:11 AM posted to rec.aviation.piloting
Mxsmanic
Orval Fairbairn writes:
A Baron and 737 are both larger.
  #133
Old January 9th 07, 02:23 AM posted to rec.aviation.piloting
Tony
Sad. So sad.
Nor that big, either, for that matter!A Baron and 737 are both larger.
  #134
Old January 9th 07, 03:23 AM posted to rec.aviation.piloting
Rip
Mxsmanic wrote:
Newps writes:
You've never flown ANYTHING AT ALL! You've merely pushed electrons
around with a joystick, and watched the associated pictures on a video
display.
Rip
  #135
Old January 9th 07, 03:46 AM posted to rec.aviation.piloting
Mxsmanic
Rip writes:
display.
As I've said, I've flown mostly a Baron and a 737.
  #136
Old January 9th 07, 03:48 AM posted to rec.aviation.piloting
Casey Wilson
"Rip" wrote in message
et...
Mxsmanic wrote:
Newps writes:
You've never flown ANYTHING AT ALL! You've merely pushed electrons around
with a joystick, and watched the associated pictures on a video display.
Rip
...........in a game by Microsoft
  #137
Old January 9th 07, 03:51 AM posted to rec.aviation.piloting
Tony
Sad. So sad.
On Jan 8, 10:46 pm, Mxsmanic wrote:
Rip writes:
display.As I've said, I've flown mostly a Baron and a 737.
  #138
Old January 9th 07, 05:15 AM posted to rec.aviation.piloting
Orval Fairbairn
But *YOU* have never flown *ANYTHING* at all -- only a low-fidelity
electronic version of the above aircraft!
I stand by my original post: "You haven't flown anything even as big as
a Cub, because you haven't flown anything!
  #139
Old January 9th 07, 08:09 AM posted to rec.aviation.piloting
Mxsmanic
As I've said, I've flown primarily a Baron 58 and a 737-800. I've
occasionally flown a Beechcraft A36 as well. I like the twin, though.
  #140
Old January 9th 07, 08:43 AM posted to rec.aviation.piloting
Duncan (NZ)
says...
Duncan writes:
What if it's a spring type system, rather than a trim tab - what is the
neutral position for that?
The same.
Which is indicated how? Please do explain.
Duncan
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
