VOR volume range
Old February 5th 07, 09:11 PM posted to rec.aviation.ifr
kevmor
Default VOR volume range
I was looking at the L1/L2 chart between RBL (Red Bluff) and SAC
(Sacramento). The change over point is at GRIDD because the airway
changes direction slightly. The only thing is, it shows the DME
distance to GRIDD from SAC as being 55nm. If I'm below 14,500, don't
all VORs have a service volume of 40nm out from the VOR?
Old February 5th 07, 09:30 PM posted to rec.aviation.ifr
Ronnie
Class H & HW VORs:
Altitude Radius
1,000' to 14,500' 40 NM
14,500' to 18,000' 100NM
18,000 to 45,000' 130NM
Class L & LW VORs:
Altitude Radius
1,000' to 18,000' 40NM
Class T VORs:
Altitude Radius
1,000' to 12,000' 25NM
I can't pull up the L1 / L2 chart or the A/FD right now.
What class VOR is SAC and what is the MEA on that
route? If the MEA is below 14,500' I'd guess that the
route was test flown and shown that reliable coverage
existed out to GRIDD.
Ronnie
"kevmor" wrote in message
ps.com...
Old February 5th 07, 09:38 PM posted to rec.aviation.ifr
kevmor
SAC is a High VOR and the MEA is 4,000. Ok, so if it's published,
then it's known to be ok on the airway. I think I remember reading
now that the volumes don't matter if it's a published procedure like
on an approach plate.
Thanks,
-Kevin
On Feb 5, 1:30 pm, "Ronnie" wrote:
Class H & HW VORs:
Altitude Radius
Class L & LW VORs:
Altitude Radius
Class T VORs:
Altitude Radius
Ronnie
ps.com...
Old February 6th 07, 12:27 AM posted to rec.aviation.ifr
kevmor
Hmm, does anyone know where this is written? Does that mean if it's
80nm to the change over point from a VOR, and the MEA is 5,000, you
can still use it at that altitude?
Thanks,
-Kevin
Class H & HW VORs:
Altitude Radius
Class L & LW VORs:
Altitude Radius
Class T VORs:
Altitude Radius
Ronnie
Old February 6th 07, 01:45 AM posted to rec.aviation.ifr
Steven P. McNicoll
ps.com...
Standard Service Volume limitations do not apply to published IFR routes or
procedures. When a procedures specialist requires the use of a NAVAID
beyond the limitations specified for SSV, an Expanded Service volume may be
established. The SAC VORTAC 329R has an ESV of 55NM at 4000.
Old February 6th 07, 01:48 AM posted to rec.aviation.ifr
Steven P. McNicoll
AIM paragraph 1-1-8.c.
Old February 6th 07, 02:58 AM posted to rec.aviation.ifr
kevmor
Thanks, I was almost looking right at it!
On Feb 5, 5:48 pm, "Steven P. McNicoll"
Old February 7th 07, 10:46 PM posted to rec.aviation.ifr
Sam Spade
Service Volumes don't apply to airways. FAA Frequency Management and
Flight Inspection supercede Service Volumes when airways are built.
Air Force FB-22 Bomber Concept - CRS Mike Naval Aviation 2 June 18th 06 09:32 PM
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 02:14 AM
To Steal an F-86 Dudley Henriques Military Aviation 19 August 1st 03 02:26 AM
