On Feb 19, 1:28 pm, "DONOTREPLY" wrote:
Can someone identify this radial aeroplane piston engine? Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes |
![]() "weasel" wrote in egroups.com... On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine? Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes No, that is not a Wright Cyclone. The engine in the picture is a double cylinder row type, but it's difficult to notice at first. Look the lower cylinder at seven o'clock and you'll see the front cylinder row push rod arrangement in front of the cylinder. Look the cylinder left side of it, at 8 o'clock and you'll see the push rod tubes behind the cylinder. That's the rear cylinder row. How about some version of Pratt & Whitney R-2800: http://www.enginehistory.org/P&W/R-2800-32W.jpg Just ignore the supercharger unit and look the front part of the engine. JP |
![]() "JP" wrote No, that is not a Wright Cyclone. The engine in the picture is a double cylinder row type, but it's difficult to notice at first. Look the lower cylinder at seven o'clock and you'll see the front cylinder row push rod arrangement in front of the cylinder. Look the cylinder left side of it, at 8 o'clock and you'll see the push rod tubes behind the cylinder. That's the rear cylinder row. I don't see it. I vote for single row. -- Jim in NC |
![]() "Morgans" wrote in ... "JP" wrote No, that is not a Wright Cyclone. The engine in the picture is a double cylinder row type, but it's difficult to notice at first. Look the lower cylinder at seven o'clock and you'll see the front cylinder row push rod arrangement in front of the cylinder. Look the cylinder left side of it, at 8 o'clock and you'll see the push rod tubes behind the cylinder. That's the rear cylinder row. I don't see it. I vote for single row. -- Jim in NC The black push rod cover tubes are visible in the picture. A double-row. http://y23stockpic.free.fr/200608-ha...27_074431.html I happen to own a small spare part inventory for this engine type (also for P&W R-1830 Twin Wasp). Trust me. It's the R-2800 Double Wasp. JP |
On 19 Feb, 22:15, "weasel" wrote:
On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine? Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes definitely looks like a 9 cylinder cylinder single row radial.... if the OP thought the radial link was interesting look at http://en.wikipedia.org/wiki/Rotary_engine :-) guy |
Definitely a double-row unit. Just look carefully at the ignbition leads
where they come off the mainn. A pair to the front cylinder, then a pair to the rear - - count them, and you'll go for an 18-cylinder setup (Oh yeah, I relize we can't see ALL of them, but from top to bottom of one side - looks abought right ?) Flash "guy" wrote in message ups.com... On 19 Feb, 22:15, "weasel" wrote: On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine? Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes definitely looks like a 9 cylinder cylinder single row radial.... if the OP thought the radial link was interesting look at http://en.wikipedia.org/wiki/Rotary_engine :-) guy |
![]() "Flash" wrote in message k.net... Definitely a double-row unit. Just look carefully at the ignbition leads where they come off the mainn. A pair to the front cylinder, then a pair to the rear - - count them, and you'll go for an 18-cylinder setup (Oh yeah, I relize we can't see ALL of them, but from top to bottom of one side - looks abought right ?) Flash "guy" wrote in message ups.com... On 19 Feb, 22:15, "weasel" wrote: On Feb 19, 1:28 pm, "DONOTREPLY" wrote: Can someone identify this radial aeroplane piston engine? Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes definitely looks like a 9 cylinder cylinder single row radial.... if the OP thought the radial link was interesting look at http://en.wikipedia.org/wiki/Rotary_engine :-) guy Also, somewhere in the general vicinity is a plaque that says it is an R2800. Or there was in April, 2006. |
On Feb 19, 2:15 pm, "weasel"
Looks like a 9-cylinder Wright R-1820 Cyclone (G?) rather severely cut- away. (wouldn't bet the farm on it tho') Wes My bad- Yes, it's an R-2800, Pratt&Whitney 18 cylinder radial. (It would've been nice if the second row was visible!!) Wes |
![]() "weasel" wrote My bad- Yes, it's an R-2800, Pratt&Whitney 18 cylinder radial. (It would've been nice if the second row was visible!!) Indeed. It looks like the view of the picture in question, with the angle given, makes it difficult to get depth of the engine. If it was a straight on view, the offset of a couple second row cylinders could have been seen and made it easy to identify the engine. If the view had been taken at a 90 degree angle from the shaft, then the second row could have been identified from the offset of crank main throws. It has always been my view that technical pictures should be taken with straight views, like a 3 view drawing. It is much easier to take measurements from a 3 view, if you are interested in taking measurements for reproducing the object as a model, or whatever. -- Jim in NC Angles like the picture given are best left for artistic presentations, as was probably intended. |
Hawai Airport Piston Engine indentification question ... | DONOTREPLY | Piloting | 7 | February 22nd 07 11:27 PM |
Learning piston engine basics | [email protected] | Owning | 9 | December 24th 05 09:19 PM |
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! | David Ross | Aviation Marketplace | 0 | August 24th 04 07:13 PM |
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? | NoSpam | Piloting | 31 | January 9th 04 01:45 AM |
Piston engine 101 Course? | [email protected] | Owning | 9 | October 28th 03 02:35 PM |
