Low fuel emergency in DFW
Old February 23rd 07, 04:23 AM posted to rec.aviation.piloting
Jim Macklin
Default Low fuel emergency in DFW
moving the other traffic is not simple when in the DFW area.
It takes time because you have to talk to each airplane and
have a place for it to go.
There will likely be an NTSB and or FAA report after an
investigation, into causes, remedies are determined. I'll
wait for that. But if the goal is to get on the ground
ASAP, consider the airplane declaring the emergency did land
safely. If a longer delay was needed to clear the airspace,
it might not have.
"Steven P. McNicoll" wrote in
message
nk.net...
| "Jim Macklin" wrote
in message
| It takes less time to fit the Tulsa to DFW flight into
| flow of traffic than it does to turn 12-30 airplanes out
of
| the way to turn the airport around. DFW, unlike many
| smaller airports never has a slack time, there are
always
| long sequenced flights.
| Departing Tulsa, by jet, to DFW is not a long
flight...why
| did they have a "fuel emergency," did they depart
without
| fuel, did they have a leak?
| They didn't know how the situation developed, they
mentioned a leak as a
| possibility.
| If the flight had insisted on landing 17, then it could
| easily have taken 30 minutes to get them a clear shot at
| runway.
| No it wouldn't. You simply move the other traffic.
| BTW, I have NEVER seen an accurate report on TV or in a
| newspaper of any airline accident or incident. NEVER!
| The tapes were part of the report. ATC was wrong, no
question about it.
Old February 23rd 07, 04:37 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Jim Macklin" wrote in message
It's easier than you think.
Old February 23rd 07, 05:57 AM posted to rec.aviation.piloting
Jim Macklin
Really, at DFW, easier than just fitting one airplane into
the stream and moving one airplane out, easier in your mind
to turn 10,20, 30 airplanes around?
message
k.net...
| "Jim Macklin" wrote
in message
area.
and
Old February 23rd 07, 10:46 AM posted to rec.aviation.piloting
Steven P. McNicoll
What is easier for ATC is not an issue. When a pilot declares an emergency
you give him whatever he wants.
Old February 23rd 07, 10:54 PM posted to rec.aviation.piloting
Jim Macklin
BS, you get then best and quickest solution.
message
ink.net...
| "Jim Macklin" wrote
in message
into
mind
Old February 24th 07, 01:02 AM posted to rec.aviation.piloting
Steven P. McNicoll
That's simply not the way it works.
Old February 23rd 07, 12:21 PM posted to rec.aviation.piloting
Matt Whiting
It is easier than having an airliner run out of fuel and crash.
Matt
Old February 23rd 07, 12:25 PM posted to rec.aviation.piloting
Mxsmanic
"Jim Macklin" writes:
There's plenty of room in the sky. You just clear a path to the runway, which
is easy. It's awkward, but any competent controller should be able to do it.
Old February 23rd 07, 12:24 PM posted to rec.aviation.piloting
Mxsmanic
Simple or not, it has to be done.
It takes only a few seconds.
it might not have.
If there is anyone on 17C, you have him clear the runway. If there is anyone
above decision height for landing, you have him go around. If he's below, you
have him land and get out of the way ASAP. Anyone taking off is similarly
vectored out of the way. Problem solved.
Everyone else is far enough away to be immediately moved out of the way. And
they'll be listening and waiting for instructions, which they will execute
instantly, you can be sure of that.
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
