CW Crane wrote:
"DavidH" wrote: Greetings flying folk, I am seeking an economical AH, or turn coordinator system. My needs are to provide some assistance when VFR and the vis is poorly or if when VFR on top the gaps are closing or on top and the cloud tops are not horozontal. . Any suggestions on minimal systems greatly appreciated. many thanks David Hill How about a turn coordinator with a small venturi vacuum source? CW Crane Carry a cat and a duck with you. If you get lost heave the duck out and follow it. If you aren't sure of which way is up heave the cat out and see which way it points its feet since they always land on their feet. I admit it's kind of hard on the cat, but they are cheaper than mechanical indicators. Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... CW Crane wrote: "DavidH" wrote: Greetings flying folk, I am seeking an economical AH, or turn coordinator system. My needs are to provide some assistance when VFR and the vis is poorly or if when VFR on top the gaps are closing or on top and the cloud tops are not horozontal. . Any suggestions on minimal systems greatly appreciated. many thanks David Hill How about a turn coordinator with a small venturi vacuum source? CW Crane Carry a cat and a duck with you. If you get lost heave the duck out and follow it. If you aren't sure of which way is up heave the cat out and see which way it points its feet since they always land on their feet. I admit it's kind of hard on the cat, but they are cheaper than mechanical indicators. Dan, U.S. Air Force, retired If you get a cat with only a couple of lives left, he will stick to the bottom of the cabin, even if that is the roof. You don't even have to throw him out, just roll until he lands on the same floor you use. Be careful following the duck, sometimes they will "duck" under and land in the pond. Al G |
On 2ÔÂ24ÈÕ, ÉÏÎç4ʱ53·Ö, Dan wrote:
CW Crane wrote: "DavidH" wrote: Greetings flying folk, I am seeking an economical AH, or turn coordinator system. My needs are to provide some assistance when VFR and the vis is poorly or if when VFR on top the gaps are closing or on top and the cloud tops are not horozontal. . Any suggestions on minimal systems greatly appreciated. many thanks David Hill How about a turn coordinator with a small venturi vacuum source? CW Crane Carry a cat and a duck with you. If you get lost heave the duck out and follow it. If you aren't sure of which way is up heave the cat out and see which way it points its feet since they always land on their feet. I admit it's kind of hard on the cat, but they are cheaper than mechanical indicators. Dan, U.S. Air Force, retired- Òþ²Ø±»ÒýÓÃÎÄ×Ö - - ÏÔʾÒýÓõÄÎÄ×Ö - Good idear! I suggested my boss to produce cats and ducks. It is easy!! Luo http://www.ming-da.com |
Solid State Artificial Horizon | nimbus | Soaring | 8 | December 31st 06 04:46 AM |
Artificial horizon pinout? | [email protected] | Home Built | 3 | July 16th 06 02:02 PM |
Artificial Horizon testing | Rory O'Conor | Soaring | 6 | April 5th 05 11:48 PM |
New artificial horizon - Sigmatek or R.C. Allen? | David Herman | Owning | 7 | November 13th 04 01:38 PM |
Artificial Horizon/Autopilot Connection | Jay Honeck | Owning | 2 | September 7th 03 05:07 PM |
