#181
![]() "Danny Deger" wrote in message ... Have you listened to the tape. It is pretty obvious that the controller was willing to give the pilot the straight-in and the supervisor said no without any rationalization. In my opinion the airspace could have been cleared, but the supervisor choose not to. Listen to the tape and tell me what you think. Had I been the controller I'd have told the supervisor that if she wanted the aircraft brought to any runway other than the one requested by the pilot she'd have to remove me from the position. |
#182
![]() "Mike Young" wrote in message t... The heavily edited tape includes enroute handing off to approach. You did not at any time hear the supervisor. What you heard was approach responding "unable" to the 17C request, not a refusal, and an expedited approach on the active. A response of "unable" is not a refusal? |
#183
On Sat, 24 Feb 2007 22:46:16 GMT, "Steven P. McNicoll"
wrote: Had I been the controller I'd have told the supervisor that if she wanted the aircraft brought to any runway other than the one requested by the pilot she'd have to remove me from the position. The controllers I've met would probably agree. But then again, they're also pilots, as I believe you are. |
#184
![]() "B A R R Y" wrote in message ... The controllers I've met would probably agree. But then again, they're also pilots, as I believe you are. I are. |
#185
On Sat, 24 Feb 2007 22:11:07 GMT, "Steven P. McNicoll"
wrote: You don't have to shut down all operations immediately for an emergency aircraft that needs to land against traffic but is still some 80 miles or so away. After listening to snow removal operations at the local Class B's & C's two weeks ago, I was surprised at how long 80 miles would be. I heard plows on the runway with inbound jets on15 mile final. 80 miles isn't exactly right there, even for a 757. At 250 knots, (under 10,000 ft) he's still almost 20 minutes out. 20 minutes is a long time! |
#186
On Sat, 24 Feb 2007 08:07:44 -0800, The Visitor wrote
(in article ): C J Campbell wrote: The pilot declared low fuel. Well that's it then isn't it. That allowed him to get priority handling with no fruther delays. And that's what he got. Pilots still are shy about saying something is an emergency, but a low fuel declaration is something specific and not an emergency(yet). There is some sort of myth that a pilot has to say the magic words "declaring an emergency" before it becomes an emergency in the eyes of either the FAA or the pilot or the law. There is no such requirement. What if the pilot passes out? Is it not an emergency just because the pilot doesn't say it is? When you are low fuel and require special handling, it is an emergency, whether anyone has actually 'declared' it or not. Same thing with fires, control failures, or anything else that is an unplanned threat to life or property that requires action to avoid it. It is a good idea to tell ATC that you have an emergency, but doing so may not always be practical or even possible. Besides, some things are just understood to be emergencies, like being so low on fuel that flying a normal approach and landing might be unsuccessful. When you are low fuel and need special handling, it is an emergency, whether you specifically say it is or not. If you were to tell ATC that you were on fire, they should treat it as an emergency whether you 'declare' one or not. If you say you have runaway trim, a hijacker, or a large flying octopus that has covered your entire windshield, it is an emergency, whether you 'declare' one or not. An unruly passenger grabbing for the controls is an emergency. Losing all your hydraulic fluid is an emergency. Landing with a flat tire is an emergency (hint: the checklist is in the "EMERGENCY PROCEDURES" section of the POH). A passenger that passes out is an emergency. There are many types of emergencies, with many different probabilities of someone being hurt or killed, but they are all emergencies. Not all emergencies have to be reported. Many emergencies are easily dealt with. But they remain emergencies nonetheless. -- Waddling Eagle World Famous Flight Instructor |
#187
If your aircraft is on fire, you need to land immediately. Availability of
fire / crash rescue resources is not an issue. Getting off the aircraft as quickly as possible is the issue. Just look at what happened with the Swissair flight over the atlantic, who took their sweet time while the were researching where the smoke was coming from. Mike Schumann "Steven P. McNicoll" wrote in message news ![]() "601XL Builder" wrDOTgiacona@suddenlinkDOTnet wrote in message news:45E0A989.1090806@suddenlinkDOTnet... MB made the point that had the aircraft been on fire that the pilot probably wouldn't have bypassed the other two airports. Did he? Perhaps you assume too much. Maybe he'd prefer the field with appropriate crash/fire/rescue capability. I think that'd be DFW. -- Posted via a free Usenet account from http://www.teranews.com |
#188
On Sat, 24 Feb 2007 16:26:46 -0800, C J Campbell
wrote: There is some sort of myth that a pilot has to say the magic words "declaring an emergency" before it becomes an emergency in the eyes of either the FAA or the pilot or the law. There is no such requirement. What if the pilot passes out? Is it not an emergency just because the pilot doesn't say it is? When you are low fuel and require special handling, it is an emergency, whether anyone has actually 'declared' it or not. FWIW, I've had airplane problems where ATC has asked me "would you like to declare?" Fortunately, I've always been able to reply to the negative, but declaring does have some significance. |
#189
![]() "Mike Schumann" wrote in message .. . If your aircraft is on fire, you need to land immediately. Availability of fire / crash rescue resources is not an issue. Getting off the aircraft as quickly as possible is the issue. Just look at what happened with the Swissair flight over the atlantic, who took their sweet time while the were researching where the smoke was coming from. Then you don't need an airport at all. |
#190
On Sat, 24 Feb 2007 16:39:15 -0800, B A R R Y wrote
(in article ): On Sat, 24 Feb 2007 16:26:46 -0800, C J Campbell wrote: There is some sort of myth that a pilot has to say the magic words "declaring an emergency" before it becomes an emergency in the eyes of either the FAA or the pilot or the law. There is no such requirement. What if the pilot passes out? Is it not an emergency just because the pilot doesn't say it is? When you are low fuel and require special handling, it is an emergency, whether anyone has actually 'declared' it or not. FWIW, I've had airplane problems where ATC has asked me "would you like to declare?" Fortunately, I've always been able to reply to the negative, but declaring does have some significance. That is true, ATC will sometimes ask that. I have not always been able to reply in the negative. :-( But even if you reply in the negative, if might still be an emergency. You and ATC just might not know it yet. :-) -- Waddling Eagle World Famous Flight Instructor |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
