#231
Some years ago I was over eastern PA in IMC and had the alternater
fail. I told NY Center I wanted to land at Lancaster because of the failure, and I was specifically asked if I wanted to declare an emergency. Of course it wasn't one, and I made no such demand, but understood that if I said that word they could clear traffic more aggressively than having to fit me into the approach patterns like a normal IFR arrivial. So they do ask, sometimes. Sometimes it's a CYA thing, but I think much more often it's ATC trying to understand how serious the problem is. On Feb 25, 8:49 am, "Steven P. McNicoll" wrote: "C J Campbell" wrote in avecable.com... Maybe Steve can elucidate what it means when ATC asks you if you would like to declare an emergency and what happens when you do. I think at least part of it is calling out the emergency equipment on the ground. I can't personally recall a controller asking a pilot if he'd like to declare an emergency. I don't believe FAAO 7110.65 ever directs a controller to ask a pilot if he'd like to declare an emergency. It does say an emergency can be declared by the controller as well as a pilot. Pilots are often hesitant to declare an emergency, but I've never known a controller to be. In situations that have the properties of an emergency ATC tends to treat it as an emergency without advising the pilot. |
#232
On Fri, 23 Feb 2007 12:16:59 +0000, Matt Whiting wrote:
I certainly don't always agree with Steven, but I'm betting he's a lot more familiar with moving airplanes out of the way that you are or than I am. Some people aren't quite thinking the situation through. Unless we're speaking of airships or helicopters or 152s or such, nobody needed to be "moved out of the way". Rather, anything moving into conflict with the pilot's intended route needs to be vectored away from the conflict. I'm not saying that that's trivial, but it's not the same thing as "moving something out of the way". There's also the fact that, no matter the emergency, it takes time for the plane with the emergency to get to any given point. So it's not as if all potential conflicts must be instantaneously handled. I don't know the DFW area. But around the EWR class B, traffic tends to follow a limited number of paths. Presumably, this helps achieve the necessary sequencing by the runway threshold. This organization too would help the vectoring. Again: I'm not saying that this is trivial. But I've no doubt that it can be done. Perhaps more difficult would be getting aircraft off the runway, if traffic on the ground were sufficiently congested. What happens if a Heavy is taxied onto grass? - Andrew |
#233
![]() "Jim Macklin" wrote in message ... Because I think they are wrong and they have not said just how they would have "cleared the airspace" in less time than was available to allow the straight in approach and landing? So because you have no idea how it can be done you concluded it can't be done. It's been stated here the airplane was about 80 miles from DFW, I don't know if that's correct but nobody has disputed it so we'll assume it is. We know it was being worked by center so it sounds about right. So figure at least 15 minutes from touchdown, that's a lot of time. Most of the arriving aircraft already within approach control airspace, perhaps all of them, can get on the ground before the emergency arrives. Other DFW bound aircraft will be held at arrival fixes or enroute. A flow control message will be sent to stop departures to DFW from at least the closer airports. Most of the departure aircraft that have already taxied will be able to depart before the emergency arrives, those that haven't taxied will be held on the ramp. Traffic at satellite fields will be largely unaffected. It certainly isn't necessary to "turn the airport around" or sterilize the airspace. What made you think it was? |
#234
![]() "Jim Macklin" wrote in message ... There really is too much speculation, TV reports are not reliable and knee-jerk reactions don't clarify the issue. The TV report played the tapes and the FAA confirmed ATC was wrong. |
#235
Mxsmanic wrote in
: If you can be confident than you have at least x minutes of fuel, then an airport that is x-y minutes away is just as close as one that is x-z minutes away. In other words, fuel is not an issue for any airports that are within your fuel endurance; the choice among those airports can therefore be based on other factors. I disagree completely. The ideal airport is the closest airport that you will reach at a reasonable descent rate. If you delay your descent until you are out of fuel, you will be in a position where you MUST make the field, and you will not be able to Go Around if there is an issue, since you are dry. OTOH, if you land at an airport that is closer than your remaining fuel, you may leave yourself with more options if the landing is less than uneventful. For example, had the AA flight waited to land until he was dry, the request to Circle to Land or the decision to land upon an active runway in the wrong direction may have had much more dire consequences. Fortunately, the flight still had fuel, so the circle to land manuever was possible. |
#236
"Al G" wrote in news:i8JDh.43$1X5.18
@newsfe05.lga: Rulebooks are paper, the will not cushion the meeting of metal and stone. I dunno... There are A LOT of rulebooks in Aviation! |
#237
Ricky Robbins wrote in
: On Fri, 23 Feb 2007 18:54:31 +1100, "d&tm" wrote: So if the pilot chose to land on R17 and crashed into a fully laden 747 that couldnt be moved in time, and 600 people died, are you saying the pilot was in his rights to ignore ATC telling him not to land? Yes, if he still considered it necessary to land on R17, he was within his rights. Now, granted, once ATC mentions the fully loaded 747 that can't be moved in time, said pilot might determine it isn't the best course of action, but the point is that once the emergency is declared it's the pilot's decision--not ATC's--whether or not to continue to R17. Rick How many of the FIVE - count 'em FIVE - parallel runways had a fully loaded 747 in Position & Hold that couldn't be moved in time? |
#238
news ![]() I don't think you understand the complexity of the airspace around DFW, with arrival gates, departure corridors, multiple runways. It is not a 1 minute or a two minute exercise to "clear the airspace" neither does a 10° heading change create legal separation in one minute. Oh, come on! Didn't you see "Pushing Tin"? ![]() Seriously, though, based on the "10 miles north of Bonham" that was described in the WFAA report (assuming that was accurate), the emergency was called about 70 NM out. At 450 Kts, that's about 10 minutes before the plane is within range. And presumably, once they get below 10,000', they'll slow down to 250 Kts allowing even more time. Plenty of time to vector even dozens of planes out of the way safely. |
#239
If the distance was correct, [first I heard or saw that was
this morning], then yes there was time. But if the plane was 20 miles out, there wasn't time. So what are the facts, not rumors reported by a TV "reporter." "Steven P. McNicoll" wrote in message ink.net... | | "Jim Macklin" wrote in message | ... | | Because I think they are wrong and they have not said just | how they would have "cleared the airspace" in less time than | was available to allow the straight in approach and landing? | | | So because you have no idea how it can be done you concluded it can't be | done. | | It's been stated here the airplane was about 80 miles from DFW, I don't know | if that's correct but nobody has disputed it so we'll assume it is. We know | it was being worked by center so it sounds about right. So figure at least | 15 minutes from touchdown, that's a lot of time. Most of the arriving | aircraft already within approach control airspace, perhaps all of them, can | get on the ground before the emergency arrives. Other DFW bound aircraft | will be held at arrival fixes or enroute. A flow control message will be | sent to stop departures to DFW from at least the closer airports. Most of | the departure aircraft that have already taxied will be able to depart | before the emergency arrives, those that haven't taxied will be held on the | ramp. Traffic at satellite fields will be largely unaffected. It certainly | isn't necessary to "turn the airport around" or sterilize the airspace. | What made you think it was? | | |
#240
![]() "Jim Macklin" wrote in message ... ATCs job in an emergency is to think straight and get the PIC priority service and on the ground ASAP within the bounds of possibilities. In this case they did neither. Think about the movie Airport, that had a snow covered runway, a stuck plane on a runway and noise complaints. Dean Martin as PIC was demanding clearance to the runway that was blocked. ATC doesn't have authority to physically clear a runway, that was about the only accurate part of that movie. No, ATC doesn't. But there are people with that authority and Burt Lancaster had ordered the snow plows to push the 707 off the runway if George Kennedy wasn't able to move it by more conventional means before the emergency aircraft arrived. Actually, "Airport" was pretty accurate, far better than it's sequels which went progressively from bad to bizarre. Priority does not mean ATC will build a runway in 30 seconds so you can land. No, it means ATC will give an aircraft in distress the right of way over all other air traffic. They didn't do that in this case, that's the error. |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
