On Mar 2, 8:41 am, Sam Spade wrote:
wrote: Some specfics will be helpful now: the airport is Flabob, KRIR, field elevation 764 MSL. I spoke with several folks and each seemed to have a different take. The TRACON controller was the most helpful/ sympathetic; he told me his Minimum Vectoring Altitude in that area is 3200 [in addition to a small hill off the departure end of RWY 24 there are taller rocks to the North]. Runway 24 takes you into the KRAL Class D almost immediately. I am sure no one likes that when they can't see you. Runway 6 is pointed towards terrain that causes the MVA to rise to 4000 quite close-in. The airport is in a terrible location both airspace and terrain-wise for IFR procedures. If you takeoff on 6 not only do you have a terrain problem there is an issue of the Ontario Class C with a floor of 2700 in that area, below any MVA. The issue witih KRAL is a non-issue as far as my question is concerned. There are many cases in which multiple towered airports are near each other and you can still get an IFR departure; both Northern and Southern California have many examples: SFO and SQL, HWD and OAK, SJC and RHV, HHR and LAX. The TRACON works it out; that is part of their job. Regarding terrain: I'm talking about a departure off 24 with a ceiling high enough to see and avoid all obstacles which, in any event, is not or should not be ATC's issue. I don't think either of these concerns is the cause of the issue here. |
On Mar 2, 11:39 am, Sam Spade wrote:
ATC does not know what ceiling you may elect on your hip-pocket ODP, nor would they care. Their concern is airspace. They cannot coordinate a procedure that is neither established nor flight inspected. Nor do they have to. |
Steven P. McNicoll wrote:
On Mar 2, 11:39 am, Sam Spade wrote: ATC does not know what ceiling you may elect on your hip-pocket ODP, nor would they care. Their concern is airspace. They cannot coordinate a procedure that is neither established nor flight inspected. Nor do they have to. You should look at the airport and airspace at issue. |
On Mar 2, 12:40 pm, Sam Spade wrote:
You should look at the airport and airspace at issue. I did. |
On Mar 2, 12:40 pm, Sam Spade wrote: You should look at the airport and airspace at issue. I did. Do you know where the closest SCT ASR antenna is to the OP's airport? |
![]() "Sam Spade" wrote in message ... Do you know where the closest SCT ASR antenna is to the OP's airport? I could easily find out if I needed to. But I don't need to. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
