Newps wrote:
Sam Spade wrote: If controlled airspace was not involved you could do what you want. But, the rub comes in them providing you a clearance into (presumably 1200-foot floor Class E airspace without some procedure that assures obstacle clearance until reaching the minimum IFR altitude. Not ATC's problem. That's 100% on the pilot. I know what you're saying, but I really do wonder. I guess it varies with the facility. SCT has been known to get spooked about such things. In any case, the OP went back to SCT and found out they don't want their airspace clobbered with an airport in a really tight airspace situation. |
![]() Sam Spade wrote: I know what you're saying, but I really do wonder. I guess it varies with the facility. SCT has been known to get spooked about such things. In any case, the OP went back to SCT and found out they don't want their airspace clobbered with an airport in a really tight airspace situation. That's perfectly understandable because you might end up shutting down a busy airport for one lousy IFR departure. But that's the reason and why they wouldn't just tell somebody that is difficult to understand. |
On Mar 2, 4:13 pm, Newps wrote:
Sam Spade wrote: I know what you're saying, but I really do wonder. I guess it varies with the facility. SCT has been known to get spooked about such things. In any case, the OP went back to SCT and found out they don't want their airspace clobbered with an airport in a really tight airspace situation. That's perfectly understandable because you might end up shutting down a busy airport for one lousy IFR departure. But that's the reason and why they wouldn't just tell somebody that is difficult to understand. But does SCT have the authority to refuse service to an airport because of inconvenience? They can certainly delay a departure, but outright refuse? What if its the middle of the night and there is very little traffic? And what if someone crashed trying to scud run to Riverside because an IFR departure were refused? Wouldn't that get the TRACON manager in trouble? |
On Mar 3, 4:22 am, Sam Spade wrote:
wrote: And what if someone crashed trying to scud run to Riverside because an IFR departure were refused? Wouldn't that get the TRACON manager in trouble? Why would it? That makes the pilot sound like a victim. Victim is taking it a bit far. I was thinking more along the lines of a denied IFR clearance being identified as contributing to an accident specifically because the OP was told to get a special VFR clearance to Riverside. And if you're worried about terrain, usually an IFR clearance will allow you to climb higher than a special VFR clearance in Class D airspace. |
a denied IFR clearance being identified as contributing to an accident specifically because the OP was told to get a special VFR clearance to Riverside. As far as I know SVFR cannot be suggested by the controller. It has to be requested by the pilot. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
On Mar 4, 6:15 am, Sam Spade wrote:
wrote: On Mar 3, 4:22 am, Sam Spade wrote: wrote: And what if someone crashed trying to scud run to Riverside because an IFR departure were refused? Wouldn't that get the TRACON manager in trouble? Why would it? That makes the pilot sound like a victim. Victim is taking it a bit far. I was thinking more along the lines of a denied IFR clearance being identified as contributing to an accident specifically because the OP was told to get a special VFR clearance to Riverside. And if you're worried about terrain, usually an IFR clearance will allow you to climb higher than a special VFR clearance in Class D airspace. I can't imagine ATC denying an IFR clearance then issuing a special VFR clearance unless the pilot requested it. I think the OP was advised of his options during a discussion about the issues at Flabob. Correct. The context was a telephone call about available options for departing Flabob and [eventually] getting on an IFR flight plan. |
![]() wrote in message ps.com... But does SCT have the authority to refuse service to an airport because of inconvenience? They can certainly delay a departure, but outright refuse? What if its the middle of the night and there is very little traffic? And what if someone crashed trying to scud run to Riverside because an IFR departure were refused? Wouldn't that get the TRACON manager in trouble? FAAO 7110.65 still requires controllers to "provide air traffic control service to aircraft on a 'first come, first served' basis as circumstances permit". Denying a departure clearance due to conflicting traffic is entirely proper, but that's not the situation here. "No instrument departure, no clearances on the ground.", as expressed by the FSDO, is simply wrong. |
Newps wrote:
Sam Spade wrote: I know what you're saying, but I really do wonder. I guess it varies with the facility. SCT has been known to get spooked about such things. In any case, the OP went back to SCT and found out they don't want their airspace clobbered with an airport in a really tight airspace situation. That's perfectly understandable because you might end up shutting down a busy airport for one lousy IFR departure. But that's the reason and why they wouldn't just tell somebody that is difficult to understand. I also have serious heartburn with some "SOP" obstacle departure procedure that probably was not "Terpsed" by AVN. Once ATC issues that puppy they put the FAA on the hook for departure obstacle clearance. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
