#51
![]() "Allan9" wrote in message ... Steve where did you find the SOCAL SOP? I got it through the FAA Facility Directives Repository while at work. I don't believe you'll be able to access the site, I can't get it through my home computer. |
#52
Jim Macklin wrote:
An IFR clearance can certainly be given to a departure in Class G that is under or abuts. You can often contact ATC and get a void time, either over the telephone or by radio if there is a near-by facility. The clearance would be something like ... ATC clears N6662U to enter controlled airspace on heading 270 at 3000 feet. Cleared to the XYZ airport, via . Contact 128.975. Clearance void if not airborne by 1730, time now 1715. Happens all the time. But, check the airspace issues at the OP's airport. |
#53
![]() "Stan Prevost" wrote in message ... Works if you can fly below 700 AGL into KRAL CDAS. And not at night. Shouldn't be too hard, if they hadn't notched the RAL Class D to exclude RIR he'd be in it at liftoff. http://map.aeroplanner.com/mapping/c...yp=APT&txt=rir |
#54
![]() "Sam Spade" wrote in message ... What I wrote was perfectly clear. If that was true clarification wouldn't be needed. |
#55
![]() "Sam Spade" wrote in message ... Do you know where the closest SCT ASR antenna is to the OP's airport? I could easily find out if I needed to. But I don't need to. |
#56
![]() "Sam Spade" wrote in message ... I said I can understand why they would not want to do it. It is more than a belief. Doubtful. I don't believe you understand the airspace issues in that area. It is different than Wisconsin. I understand airspace issues everywhere, this is not an airspace issue. |
#57
![]() "Sam Spade" wrote in message ... You should call her back and tell her that Steve McNicoll says she is wrong and doesn't know what she is doing. ;-) Since an SOP does exist she is definitely wrong when she says there isn't one. Whether or not she knows what she is doing can not be determined from available information. Seriously, that 1,400+ hill to the west of the airport blocks the radar site at KONT. I doubt they can see you until your well into KRAL's Class D. So what? |
#58
![]() "Sam Spade" wrote in message ... But, check the airspace issues at the OP's airport. What do you believe the airspace issues are? |
#59
Newps wrote:
Sam Spade wrote: If controlled airspace was not involved you could do what you want. But, the rub comes in them providing you a clearance into (presumably 1200-foot floor Class E airspace without some procedure that assures obstacle clearance until reaching the minimum IFR altitude. Not ATC's problem. That's 100% on the pilot. I know what you're saying, but I really do wonder. I guess it varies with the facility. SCT has been known to get spooked about such things. In any case, the OP went back to SCT and found out they don't want their airspace clobbered with an airport in a really tight airspace situation. |
#60
Steven P. McNicoll wrote:
"Sam Spade" wrote in message ... Do you know where the closest SCT ASR antenna is to the OP's airport? I could easily find out if I needed to. But I don't need to. Well, if you did you would find it is blocked by terrain between it and RIL. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
