In article .com,
"Bob Kuykendall" wrote: These electric pumps, according to an informal survey of friends and acquaintances, fail with alarming frequency - usually within ~50K miles and each 50K thereafter. That's counter to my personal experience. I've done four fuel pumps for my Volvo tow vehicles; none of them let go prior to the 200,000 mile mark. All of the replacements outlasted the vehicles. Once you are on the roadside, you will find that no matter how good you may be at fixing cars, there is nothing you can do but call a tow truck since pump replacement requires a high bay hoist where the gas tank can be removed. It just isn't a DIY job. Disagree: A) Everything is DIY for the resourceful and motivated. B) All of the cars for which I've replaced the in-tank pump allowed access through a panel in the trunk or under the cargo deck. None so far have required dropping the tank. C) For many cars with Bosch K-Jetronic, LH-Jetronic, and similar systems, there are actually two pumps: an in-tank centrifugal pump and an external constant-displacement pump. The in-tank pump just delivers fuel to the main pump, and is critical only at 1/4 tank fuel level and below. The usual sign of a failed or failing in-tank pump is poor running below 1/4 tank, and whining noises from the main pump. D) In my experience, failure of fuel pump relays is far more common than failure of the pump. Usually they can be fixed by peeling them open and resoldering the crack-prone joints where the heavy relay frame meets the circuit board. My tow vehicle is a '92 Dodge full size hightop van, 6 cylinder. It only has one fuel pump and it's in the tank. No access to it from on top. The tank has to be dropped. The fuel pump failed at 140k miles - exactly at the halfway point of a 350 mile trip - on Thanksgiving day. Nearly every system on this van has had a failure. I think I've replaced everything but the engine block and one of the hubcaps. I really enjoy the hightop room, but this thing is a piece of crap. Glad I didn't pay much for it. Oh, and take a look at the repair manual for these things. Dodge full size vans had essentially no mechanical changes from 1977 through at least 2001. So much for innovation and improvement. If Toyota ever makes a full size van, I'm gettin' one. |
On Mar 3, 12:58 am, Berry wrote:
In article .com, "Bob Kuykendall" wrote: These electric pumps, according to an informal survey of friends and acquaintances, fail with alarming frequency - usually within ~50K miles and each 50K thereafter. That's counter to my personal experience. I've done four fuel pumps for my Volvo tow vehicles; none of them let go prior to the 200,000 mile mark. All of the replacements outlasted the vehicles. Once you are on the roadside, you will find that no matter how good you may be at fixing cars, there is nothing you can do but call a tow truck since pump replacement requires a high bay hoist where the gas tank can be removed. It just isn't a DIY job. Disagree: A) Everything is DIY for the resourceful and motivated. B) All of the cars for which I've replaced the in-tank pump allowed access through a panel in the trunk or under the cargo deck. None so far have required dropping the tank. C) For many cars with Bosch K-Jetronic, LH-Jetronic, and similar systems, there are actually two pumps: an in-tank centrifugal pump and an external constant-displacement pump. The in-tank pump just delivers fuel to the main pump, and is critical only at 1/4 tank fuel level and below. The usual sign of a failed or failing in-tank pump is poor running below 1/4 tank, and whining noises from the main pump. D) In my experience, failure of fuel pump relays is far more common than failure of the pump. Usually they can be fixed by peeling them open and resoldering the crack-prone joints where the heavy relay frame meets the circuit board. My tow vehicle is a '92 Dodge full size hightop van, 6 cylinder. It only has one fuel pump and it's in the tank. No access to it from on top. The tank has to be dropped. The fuel pump failed at 140k miles - exactly at the halfway point of a 350 mile trip - on Thanksgiving day. Nearly every system on this van has had a failure. I think I've replaced everything but the engine block and one of the hubcaps. I really enjoy the hightop room, but this thing is a piece of crap. Glad I didn't pay much for it. Oh, and take a look at the repair manual for these things. Dodge full size vans had essentially no mechanical changes from 1977 through at least 2001. So much for innovation and improvement. If Toyota ever makes a full size van, I'm gettin' one. Bill, why the sudden concern about landing out? and finding any reason possible to avoid it at all costs? Mechanical breakdowns are a possibility no matter what we drive (or fly). Its something we may have to deal with and a risk we take. |
![]() Aren't you flying something that resembles more a hollowed-out log than a mechanical device? ![]() HA. Only when Im in my glider. That other 2 or 300 hours I get in the air every year is behind a stinky loud engine. Sometimes 2! |
Rapco 215/216 vacuum pumps? | Jim Burns | Owning | 9 | May 1st 06 06:29 PM |
Vacuum pumps | vk6ad | Owning | 1 | March 10th 06 03:23 PM |
EMERGENCY AIR PUMPS | [email protected] | Soaring | 7 | January 30th 06 11:29 PM |
Problems with Rapco dry vacuum pumps. | abripl | Owning | 28 | September 25th 05 05:29 AM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
