Right magneto is "hot" (ungrounded). The "OFF" position grounds both
mags. That was my understanding too, but after arguing the point with two very experienced pilots yesterday, I wondered how prevalent the contrary view might be. Most pilots don't understand much about aircraft systems, and many who have automobile maintenance experience don't understand magnetos. They make a lot of assumptions and sometimes harbour many misconceptions. A magneto's primary winding is grounded to kill it, so when the key is in the R position, the L magneto is grounded, and vice versa. Even the terminals on back of the switch are labelled R and L and when the appropriate positions are selected, the other terminal is grounded. Can confuse someone trying to test the switch itself unless they know what the principles are. Another misconception: that the magneto is somehow connected to the aircraft's electrical system. They're afraid to turn off the master switch in flight lest it kill the engine. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. |
"Peter Dohm" wrote in message
... Right magneto is "hot" (ungrounded). The "OFF" position grounds both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. |
On Mar 3, 5:11 pm, "Travis Marlatte"
wrote: I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. Here's one reason (and this scenario initiated the post in the first place). My 182 failed the run-up yesterday on the "left" mag. I knew which cylinder it was through my JPI. But which plug? The upper plug is easy to check, but the lower requires removal of the lower cowling, which is a 2-person job to replace. |
both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. No, but he should know that that the Right mag is hot (firing plugs) and the Left mag is cold (not firing) when the switch is in the "R" position, and that the Right mag is cold (not firing) and the Left mag is hot (firing plugs) when the switch is in the "L" position. That much systems knowledge would seem usefull for a safe and reasonable Go/NoGo decision prior to take-off, and also to explain a problem to an efficient manner. Knowledge of the specifics of how the ignition system works could be very usefull in the case of "stealing your oun airplane" because you lost the key at a remote hunting/fishing spot; but I can not imagine that being part of an accredited licensing test. Peter |
![]() "Peter Dohm" wrote in message ... : : No, but he should know that that the Right mag is hot (firing plugs) and the : Left mag is cold (not firing) when the switch is in the "R" position, and : that the Right mag is cold (not firing) and the Left mag is hot (firing : plugs) when the switch is in the "L" position. That much systems knowledge : would seem usefull for a safe and reasonable Go/NoGo decision prior to : take-off, and also to explain a problem to an efficient manner. : : Knowledge of the specifics of how the ignition system works could be very : usefull in the case of "stealing your oun airplane" because you lost the key : at a remote hunting/fishing spot; but I can not imagine that being part of : an accredited licensing test. : : Peter : : But they sure as heck should know that turning off the master switch will not turn off their engine. |
There are some old engines that did use battery power for
the ignition and in those, the battery master must be on. But, in general aircraft built in the post WWII period have two independent magnetos and the battery is used for lights, starting and radios, etc. Some aircraft had one magneto and one coil/distributor [like a car], so the AFM/POH should be read. Also ignition operation should be checked on the ground as part of the pre or post-flight checklists. "Blueskies" wrote in message t... | | "Peter Dohm" wrote in message ... | : | : No, but he should know that that the Right mag is hot (firing plugs) and the | : Left mag is cold (not firing) when the switch is in the "R" position, and | : that the Right mag is cold (not firing) and the Left mag is hot (firing | : plugs) when the switch is in the "L" position. That much systems knowledge | : would seem usefull for a safe and reasonable Go/NoGo decision prior to | : take-off, and also to explain a problem to an efficient manner. | : | : Knowledge of the specifics of how the ignition system works could be very | : usefull in the case of "stealing your oun airplane" because you lost the key | : at a remote hunting/fishing spot; but I can not imagine that being part of | : an accredited licensing test. | : | : Peter | : | : | | But they sure as heck should know that turning off the master switch will not turn off their engine. | | |
![]() "Jim Macklin" wrote in message ... : There are some old engines that did use battery power for : the ignition and in those, the battery master must be on. : But, in general aircraft built in the post WWII period have : two independent magnetos and the battery is used for lights, : starting and radios, etc. Some aircraft had one magneto and : one coil/distributor [like a car], so the AFM/POH should be : read. Also ignition operation should be checked on the : ground as part of the pre or post-flight checklists. : : : How old are you talking, Jim? Any specifics? Engine, airframe? |
On Sat, 3 Mar 2007 19:11:50 -0600, "Travis Marlatte"
wrote: "Peter Dohm" wrote in message .. . Right magneto is "hot" (ungrounded). The "OFF" position grounds both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. On the right (or left) looking toward the propeller, or t'other way round? (And tractor or pusher? And are the mag designations different on the two engines in a Cessna 337?) Maybe it's time to label mag switches Port and Starboard, mateys! Don |
"Travis Marlatte" wrote: "Peter Dohm" wrote in message ... Right magneto is "hot" (ungrounded). The "OFF" position grounds both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. So you can tell which mag has the problem -- ehether it is plugs, harness or the magneto itself. Sometimes it is just a fouled plug; other times it is a dirty cigarette; other times it is a loose harness connection. Learn it and use it! |
"Orval Fairbairn" wrote in message
news ![]() In article , "Travis Marlatte" wrote: "Peter Dohm" wrote in message ... Right magneto is "hot" (ungrounded). The "OFF" position grounds both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. So you can tell which mag has the problem -- ehether it is plugs, harness or the magneto itself. Sometimes it is just a fouled plug; other times it is a dirty cigarette; other times it is a loose harness connection. Learn it and use it! You and Peter seem pretty set on this and I don't quite understand why. Here's two scenarios I'm thinking about: 1) I do a mag check and notice that I don't get an RPM drop on the Left (or Right) position. So I taxi over to the garage and I say to the guy, I says, "Say! I think I may have a broken P-lead. Do you have time to fix it while I go get some lunch?" 2) I do a mag check and notice that the engine runs rough on the Left (or Right) position. So I taxi over to the garage and I say to the guy, I says, "Say! I think I may have a fouled plug that I couldn't clear with leaning. Do you have time to fix it while I go get some lunch?" Now, if I happened to be out on a lake somewhere and had a fouled plug that wouldn't clear, I'd walk over to my tackle box, see, and pull out the green, spotted jitter bug. 'Cause when I'm desperate for dinner, that's what I always use. In the morning, I'd pull all four of the lower plugs because by the time I translated left or right for top or bottom on the left or right side, I'd... well, I'd rather be fishing and, chances are, it's one of the lower plugs. ------------------------------- Travis Lake N3094P PWK |
Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 08:39 PM |
74 Archer ignition switch question | Mike Noel | Owning | 9 | September 10th 06 10:46 PM |
Ignition switch, what happen when Left or Right is selected | Martin B | Piloting | 41 | May 21st 05 04:55 AM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Just Ordered: An Ignition Switch and Oil Filter from ACS | Larry Smith | Home Built | 30 | October 22nd 03 07:41 AM |
