On Mar 4, 6:15 am, Sam Spade wrote:
wrote: On Mar 3, 4:22 am, Sam Spade wrote: wrote: And what if someone crashed trying to scud run to Riverside because an IFR departure were refused? Wouldn't that get the TRACON manager in trouble? Why would it? That makes the pilot sound like a victim. Victim is taking it a bit far. I was thinking more along the lines of a denied IFR clearance being identified as contributing to an accident specifically because the OP was told to get a special VFR clearance to Riverside. And if you're worried about terrain, usually an IFR clearance will allow you to climb higher than a special VFR clearance in Class D airspace. I can't imagine ATC denying an IFR clearance then issuing a special VFR clearance unless the pilot requested it. I think the OP was advised of his options during a discussion about the issues at Flabob. Correct. The context was a telephone call about available options for departing Flabob and [eventually] getting on an IFR flight plan. |
On Mar 5, 1:41 pm, Sam Spade wrote:
wrote: Correct. The context was a telephone call about available options for departing Flabob and [eventually] getting on an IFR flight plan. Is your aircraft based there? If so, do you know whether the airport owners/management have ever requested an IFR approach for the airport? A GPS approach would work there, but it would have fairly high minimums and probably be circling only. But, that would result in an ODP being published for Runway 24 and, perhaps, Runway 6. Yes, I am based there now. I do not know whether an approach has been requested. Having an ODP, while nice, doesn't change the fact that an ODP is not required to depart IFR from an airport without an approach. Based on all I know, except for the inconvenient fact that the RAL VOR is OTS indefinitely, the SOP referred to earlier should be all that is necessary. In lieu of an SOP, so far as I can tell, a clearance with a void time should be issued, traffic permitting. |
akucheck wrote:
On Mar 5, 1:41 pm, Sam Spade wrote: wrote: Correct. The context was a telephone call about available options for departing Flabob and [eventually] getting on an IFR flight plan. Is your aircraft based there? If so, do you know whether the airport owners/management have ever requested an IFR approach for the airport? A GPS approach would work there, but it would have fairly high minimums and probably be circling only. But, that would result in an ODP being published for Runway 24 and, perhaps, Runway 6. Yes, I am based there now. I do not know whether an approach has been requested. Having an ODP, while nice, doesn't change the fact that an ODP is not required to depart IFR from an airport without an approach. Based on all I know, except for the inconvenient fact that the RAL VOR is OTS indefinitely, the SOP referred to earlier should be all that is necessary. In lieu of an SOP, so far as I can tell, a clearance with a void time should be issued, traffic permitting. It is apparent that today's SoCal management does not like the SOP. As someone who works with this stuff all the time, I understand their concern. This is not a typical Class G airport departure. The area terps require a climb gradient in excess of 400 feet per mile because of terrain. The controlling terrain is in the RAL Class D area so, other views notwithstanding, that creates a fair amount of liability on the part of the FAA. If you had an RNAV IAP, you would have an RNAV ODP, with would be navaid independent. |
![]() "Sam Spade" wrote in message ... It is apparent that today's SoCal management does not like the SOP. As someone who works with this stuff all the time, I understand their concern. How is it that you can work with "this stuff" all the time and still have such a poor understanding of it? |
Steven P. McNicoll wrote:
"Sam Spade" wrote in message ... It is apparent that today's SoCal management does not like the SOP. As someone who works with this stuff all the time, I understand their concern. How is it that you can work with "this stuff" all the time and still have such a poor understanding of it? Why don't you lay out the required TERPs ODP initial climb area for Runway 24 at RIR, then we can compare who has the understanding. |
Departure procedures notice | Jim Macklin | Instrument Flight Rules | 12 | January 27th 07 02:57 PM |
Fedex Departure (MCO) | Glen in Orlando | Aviation Photos | 0 | November 29th 06 11:13 PM |
Alternate same as departure? | dlevy | Instrument Flight Rules | 34 | December 11th 04 01:15 PM |
Uncontrolled airport departure-again... | endre | Instrument Flight Rules | 13 | March 1st 04 12:42 AM |
gliding back to your departure airport | Harold | Piloting | 34 | October 24th 03 11:12 PM |
