Ignition switch settings
Old March 5th 07, 06:28 PM posted to rec.aviation.piloting
Default Ignition switch settings
On Mar 5, 11:04 am, "Morgans" wrote:
wrote
Yup, on Lycoming. Continental, at least on the smaller engines,
will have the right mag firing the top plugs and the left firing the
bottom. The impulse mag (right) fires the top plugs, since they're
less likely to get wet with oil or fuel.
I think you mis-interpreted his comments. He said (at least I think he
said) that one mag fires the top plugs on the left cylinders and the same
mag fires the bottom plugs on the right side cylinders.
Jim in NC
No, that's what I meant. On the Lycoming the left mag fires the
bottom left-side plugs and right top-side plugs. The RH mag fires the
top LH and bottom RH plugs. Continental's smaller engines have the
mags firing all the top or all the bottom plugs, and the larger
engines are arranged like Lycomings.
Dan
Old March 5th 07, 09:59 PM posted to rec.aviation.piloting
DL
On my "larger Continental" the left mag fires top plugs on left side and
bottom plugs on right side. Vice versa for right mag.
DL
ps.com...
Dan
Old March 5th 07, 11:59 PM posted to rec.aviation.piloting
Stan Prevost[_1_]
ps.com...
Haven't followed the whole thread, but on my Lycoming, the left mag fires
all top plugs (TIO540-AH1A).
San
Old March 6th 07, 12:23 AM posted to rec.aviation.piloting
Morgans[_2_]
How 'bout that. I misinterpreted what _you_ meant.
Jim in NC
Old March 6th 07, 01:31 AM posted to rec.aviation.piloting
Orval Fairbairn
On my O-435 Lycoming the Right mag fires the top right and bottom left;
the Left mag fires top left and bottom right.
This arrangement is standard per Lycoming Overhaul manual for both 4-
qnd 6-cylinder engines.
Nav radio settings in FMC Mxsmanic Piloting 5 January 10th 07 08:39 PM
74 Archer ignition switch question Mike Noel Owning 9 September 10th 06 10:46 PM
Ignition switch, what happen when Left or Right is selected Martin B Piloting 41 May 21st 05 04:55 AM
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Just Ordered: An Ignition Switch and Oil Filter from ACS Larry Smith Home Built 30 October 22nd 03 07:41 AM
