"Morgans" wrote: wrote No, that's what I meant. On the Lycoming the left mag fires the bottom left-side plugs and right top-side plugs. The RH mag fires the top LH and bottom RH plugs. Continental's smaller engines have the mags firing all the top or all the bottom plugs, and the larger engines are arranged like Lycomings. How 'bout that. I misinterpreted what _you_ meant. On my O-435 Lycoming the Right mag fires the top right and bottom left; the Left mag fires top left and bottom right. This arrangement is standard per Lycoming Overhaul manual for both 4- qnd 6-cylinder engines. |
Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 08:39 PM |
74 Archer ignition switch question | Mike Noel | Owning | 9 | September 10th 06 10:46 PM |
Ignition switch, what happen when Left or Right is selected | Martin B | Piloting | 41 | May 21st 05 04:55 AM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Just Ordered: An Ignition Switch and Oil Filter from ACS | Larry Smith | Home Built | 30 | October 22nd 03 07:41 AM |
