chris writes:
It has retractable gear and variable pitch props, means it's complex. Not to mention multi-engine. The FAA seems to have a low threshold of complexity. You would be very ill-advised to try and start your flight training in a twin. There's way too much stuff to cope with when you're trying to learn how to take off, fly s+l and land.. I've heard of other people doing it, although it seems to be rare. If that's the aircraft I wanted to fly, wouldn't it be more practical to just start with it to begin with? Best to learn on something small, slow, forgiving, and you can move up later. I found even going from a C152 to an Archer, I got way behind the aircraft - too much happening too fast, and the Archer doesn't have two engines, CSU's or retract. And the difference in cruise is only 35kt or so, but enough to get me seriously behind the aircraft!! What sorts of things were you losing track of in the Archer? If you are floating you are going too fast or trying to hold it off too long. From reading your earlier post, you identified the VSo of the Baron as 75. That's the lower limit of the white band, which (IIRC) is the VSo with flaps extended. I usually stay above Vmc (the first red line) on landing, and I usually won't rotate until I'm above Vyse (the first blue line) at take-off. The engine-out scenarios I've practiced are harrowing and I always like to be going fast enough to deal with those. (I haven't practiced engine failure on landing yet, however.) My research came up with 69-72 as stall speeds. Which makes VSo x1.3 = 89-93kt. That's very often my speed at touchdown. I never try to stall into touchdown, despite what I've read here. My theory is that being at stall speed gives you no options, even if it's the slowest possible touchdown speed. In an emergency, I want to be able to leave the runway again, but I'm not going anywhere once I stall. You probably don't want to be going for a full stall landing in a twin, so come in at about 90kt, raise the nose a bit to flare and let it settle onto the runway. That's what I do, more less. I descend until about ten feet or so then hold the aircraft level and set throttles to idle (they are slightly above prior to that). That causes the aircraft to settle downwards and as it does so I flare. If my approach was stable and if it's not too windy I can barely feel the wheels touch. If I've been crabbing for a crosswind this is also when I straighten the aircraft out. Why do you say a stall landing is inadvisable "in a twin"? Would it be different for a single-engine plane? Don't try and hold it off, that's what a Cessna pilot should do, but probably not a twin pilot. Here again, why the distinction between single and twin? Just make sure your mains touch before your nose wheel. That's usually not a problem, although in landings that have collapsed gear, sometimes the nose gear goes first. It seems that a hard landing in the Baron tends to pitch the nose downward so that the nose gear hits even harder than the main gear, and then it breaks. (Incidentally, MSFS doesn't count that as a crash, but the aircraft is still unflyable afterwards.) Mind you, I am not a twin pilot so that could all have been rubbish. I don't understand why 1 vs 2 engines is such a big deal. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: chris writes: It has retractable gear and variable pitch props, means it's complex. Not to mention multi-engine. The FAA seems to have a low threshold of complexity. Just consider it a term of art. |
Pixel Dent writes:
Just consider it a term of art. I've concluded that it's just another one of those arbitrary anachronisms that seem to haunt the FAA. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Mar 7, 6:03 pm, Mxsmanic wrote:
chris writes: It has retractable gear and variable pitch props, means it's complex. Not to mention multi-engine. The FAA seems to have a low threshold of complexity. The term complex has little meaning where I live - if I transition to say a Twin Comanche, I will need separate training on and ratings for retractable gear, CSU and multi. Each has it's own ins and outs, as I think I will find out shortly when I go for an Arrow rating - that has retract and CSU. You would be very ill-advised to try and start your flight training in a twin. There's way too much stuff to cope with when you're trying to learn how to take off, fly s+l and land.. I've heard of other people doing it, although it seems to be rare. If that's the aircraft I wanted to fly, wouldn't it be more practical to just start with it to begin with? I have heard of one person who did it, but I think for the majority of people it would be hard to cope with all the stuff you need to deal with to fly a twin, Best to learn on something small, slow, forgiving, and you can move up later. I found even going from a C152 to an Archer, I got way behind the aircraft - too much happening too fast, and the Archer doesn't have two engines, CSU's or retract. And the difference in cruise is only 35kt or so, but enough to get me seriously behind the aircraft!! What sorts of things were you losing track of in the Archer? What I found was that it felt substantially faster, it climbed a lot quicker, and was harder to slow down. I also found the fuel management to be extra complexity I didn't need.. For an average circuit in a 152, I would be waiting for it to get to circuit altitude, had time to do my checks, and it slowed down quickly with flap out. The archer, on the other hand, I found I had to turn downwind, level out, pull the power back, and trim, all at the same time, then pull the power right back or I would run over the guy in front. Then when I put flap out it didn't slow down. Then you have to somehow slow down and get down at the same time. I have 150 hours of Archer time now, and am perfectly comfortable with doing all of the above, but it was harrowing to begin with!! If you are floating you are going too fast or trying to hold it off too long. From reading your earlier post, you identified the VSo of the Baron as 75. That's the lower limit of the white band, which (IIRC) is the VSo with flaps extended. I usually stay above Vmc (the first red line) on landing, and I usually won't rotate until I'm above Vyse (the first blue line) at take-off. The engine-out scenarios I've practiced are harrowing and I always like to be going fast enough to deal with those. (I haven't practiced engine failure on landing yet, however.) I have no idea about that stuff, but if you're happy with it... My research came up with 69-72 as stall speeds. Which makes VSo x1.3 = 89-93kt. That's very often my speed at touchdown. I never try to stall into touchdown, despite what I've read here. My theory is that being at stall speed gives you no options, even if it's the slowest possible touchdown speed. In an emergency, I want to be able to leave the runway again, but I'm not going anywhere once I stall. You really want the aircraft to be going slow enough to stop flying on it's own. Remember if you want to leave the runway again you'll have to put power on anyway. You probably don't want to be going for a full stall landing in a twin, so come in at about 90kt, raise the nose a bit to flare and let it settle onto the runway. That's what I do, more less. I descend until about ten feet or so then hold the aircraft level and set throttles to idle (they are slightly above prior to that). That causes the aircraft to settle downwards and as it does so I flare. If my approach was stable and if it's not too windy I can barely feel the wheels touch. If I've been crabbing for a crosswind this is also when I straighten the aircraft out. Sounds good to me.. Why do you say a stall landing is inadvisable "in a twin"? Would it be different for a single-engine plane? If I got this right (twin drivers please confirm or deny this), there is a lot of weight up front with those engines hanging so far forward, which makes holding the nose off a real bugger, and especially on things like Twin Comanche's they tend to stop flying with a bit of a bang, so you are best advised to just fly it into the runway... Don't try and hold it off, that's what a Cessna pilot should do, but probably not a twin pilot. Here again, why the distinction between single and twin? I am a single engine pilot, please see above for my admittedly limited understanding.. Just make sure your mains touch before your nose wheel. That's usually not a problem, although in landings that have collapsed gear, sometimes the nose gear goes first. It seems that a hard landing in the Baron tends to pitch the nose downward so that the nose gear hits even harder than the main gear, and then it breaks. (Incidentally, MSFS doesn't count that as a crash, but the aircraft is still unflyable afterwards.) You really don't want to break gear off in sim or real life :-) Mind you, I am not a twin pilot so that could all have been rubbish. I don't understand why 1 vs 2 engines is such a big deal. See above.. |
![]() I have heard of one person who did it, but I think for the majority of people it would be hard to cope with all the stuff you need to deal with to fly a twin, Oops.. I meant to say.. It would be hard to cope with all that stuff while learning the basics of flying, like circuits, approaches, landings... Judging by what I experienced, the average student pilot would probably find anything much more complicated than a 172 or Archer to be just overwhelming. More things to remember = more things to forget :-) |
chris writes:
Judging by what I experienced, the average student pilot would probably find anything much more complicated than a 172 or Archer to be just overwhelming. More things to remember = more things to forget :-) But following that logic, people who learn to drive with a manual transmission should have more trouble than those who learn to drive with an automatic, and yet that does not seem to be the case. They both seem to learn at about the same speed. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Mar 8, 8:54 pm, Mxsmanic wrote:
chris writes: Judging by what I experienced, the average student pilot would probably find anything much more complicated than a 172 or Archer to be just overwhelming. More things to remember = more things to forget :-) But following that logic, people who learn to drive with a manual transmission should have more trouble than those who learn to drive with an automatic, and yet that does not seem to be the case. They both seem to learn at about the same speed. I sort of meant that I remember having issues with trying to remember everything while doing a circuit - I couldn't have coped with also having to manipulate landing gear and prop controls, not to mention multiple engines.. |
chris schrieb:
I sort of meant that I remember having issues with trying to remember everything while doing a circuit - I couldn't have coped with also having to manipulate landing gear and prop controls, not to mention multiple engines.. That's why an instructor is with you. If all you want is to fly twins, then the only reason to not directly learn in a twin is financial. This is a very strong reason, though. Of course there can be other benefits in learning to fly in a basic airplane, like learning to fly by the seat of your pants, learning to cope with unimproved backcountry strips and the like, but it seems that the vast majority of students don't learn that in a 172 either. |
![]() But following that logic, people who learn to drive with a manual transmission should have more trouble than those who learn to drive with an automatic, and yet that does not seem to be the case. They both seem to learn at about the same speed. -- Transpose mxsmanic and gmail to reach me by e-mail. In the UK if you learn to drive using a car with an automatic gear box you ARE NOT PERMITTED to drive a manual geared car. You must take lessons and an examination to do so. Ibby |
![]() You would be very ill-advised to try and start your flight training in a twin. There's way too much stuff to cope with when you're trying to learn how to take off, fly s+l and land.. I've heard of other people doing it, although it seems to be rare. If that's the aircraft I wanted to fly, wouldn't it be more practical to just start with it to begin with? I also forgot to mention that since vastly experienced pilots still die from getting it wrong after an engine failure in a twin, how do you think a newly solo student could deal with it?? |
ID Please - Throttle Quad | Orval Fairbairn | Restoration | 0 | December 17th 05 08:35 PM |
Throttle movement | Max Richter | Naval Aviation | 12 | December 11th 04 11:09 PM |
Engine throttle | Bob Ingraham | Simulators | 13 | December 11th 04 07:17 PM |
Which throttle governer? | Garfiel | Rotorcraft | 1 | December 13th 03 04:30 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
