This makes me just a little curious.
Is the handbrake on a Piper (without toe brakes) mechanical or hydraulic? I presume you're meaning on aircraft like the TriPacer which has the hand brake, but no toe brakes. In the TriPacer, a cable goes from the hand brake, around a few pulleys, and ultimately it ends up under the pilot's seat. Under the pilot's seat (and I'm not joking) you will find a Piper Cub heel brake, with a hole in the back of the heel brake, where the cable connects. The heel brake is hydraulic and applies both wheel brakes simultaneously. The diaphragm has a habit of splitting just when you really need the brakes, leaving you with nothing! -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Yes, that was the question. BTW, your description of the TriPacer hand brake is a great example of the way existing inventory happens to find an additional use. It reminds me of a conversation I witnessed a few years ago at a combination picnic and hangar-invasion. One of the members was in the process of building a Pitts Special from plans--and lamented the difficulty of fabricating the elevator linkage adaptor (for want of better nomenclature) which attached to the control stick. Another member took one glance and said "that ol' son of a gun just cut the top off [of] a cow bell". Peter |
![]() In the TriPacer, a cable goes from the hand brake, around a few pulleys, and ultimately it ends up under the pilot's seat. Under the pilot's seat (and I'm not joking) you will find a Piper Cub heel brake, with a hole in the back of the heel brake, where the cable connects. The heel brake is hydraulic and applies both wheel brakes simultaneously. The diaphragm has a habit of splitting just when you really need the brakes, leaving you with nothing! -- Unless you put in an STC'd booster from Steve's Aircraft Then you really have brakes whenever you really need them. :-) Cheers: Paul N1431A |
timing holds | [email protected] | Instrument Flight Rules | 16 | February 17th 05 12:18 AM |
Approach Timing | john smith | Instrument Flight Rules | 36 | September 9th 04 03:37 PM |
Timing light for electronic ignition | Ron | Home Built | 4 | August 20th 04 05:18 PM |
internal timing of slick magneto | Jerry Jensen | Home Built | 1 | June 25th 04 07:59 PM |
Timing on Subaru EJ22 ??? | Randy | Rotorcraft | 1 | November 9th 03 06:15 AM |
