#81
Hi,
In article .com, wrote: Which makes sense... I mean heck, sometimes I think that automobile drivers should be certified for manual transmissions. I see way too many drivers who are very scary to be behind, when starting on hills with their new 5-speed ;-) In the UK, they are. You can either take your driving test in a manual or an automatic. If you take it in a manual, you can drive either. If you take it in an automatic, you can only drive automatics. Andy |
#82
automatic. If you take it in a manual, you can drive either. If you take it in an automatic, you can only drive automatics. In the US it's the reverse. If you take it (or took it when I did, mumble years ago) in a manual, that's all you could drive. If you took it in an automatic, you could drive both. Go figure. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
#83
Hi,
In article , wrote: In the US it's the reverse. If you take it (or took it when I did, mumble years ago) in a manual, that's all you could drive. If you took it in an automatic, you could drive both. Go figure. ??? So they reckon it's harder to drive an auto than a manual? The mind boggles ![]() Andy |
#84
I reckon it has to do with using the otherwise occupied foot for the brakes. But that's just a guess. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
#85
Jose wrote:
In the UK, they are. You can either take your driving test in a manual or an automatic. If you take it in a manual, you can drive either. If you take it in an automatic, you can only drive automatics. In the US it's the reverse. If you take it (or took it when I did, mumble years ago) in a manual, that's all you could drive. If you took it in an automatic, you could drive both. Go figure. The US is a very big place with several different state laws that change from time to time. Unless you change the US to some more specific location and maybe even specific date you are just plain wrong. |
#86
Andy Hawkins writes:
So they reckon it's harder to drive an auto than a manual? A car with an automatic transmission is perhaps considered "complex." -- Transpose mxsmanic and gmail to reach me by e-mail. |
#87
Gig 601XL Builder writes:
The US is a very big place with several different state laws that change from time to time. Unless you change the US to some more specific location and maybe even specific date you are just plain wrong. Correction: Your rightness or wrongness is indeterminate. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#88
Jose wrote:
In the UK, they are. You can either take your driving test in a manual or an automatic. If you take it in a manual, you can drive either. If you take it in an automatic, you can only drive automatics. In the US it's the reverse. If you take it (or took it when I did, mumble years ago) in a manual, that's all you could drive. If you took it in an automatic, you could drive both. Go figure. Huh? That makes absolutely ZERO sense. (okay, it was gub'mint) |
#89
Sounds doable, with a bit of practice.
Of course its doable, we do it all the time. I don't have much trouble with it in the sim. Utterly irrelevant statement... You mastery of an arbitrary task-load designed to approximate a pilot's workload with a substantially constrained interface says nothing. |
#90
"Mxsmanic" wrote in message
... ... How far above the runway? And you don't stall or get a tail strike? Of course, something like an Archer likes to be landed a little hotter, without having full back stick. In the Baron I don't think I've ever pulled the yoke all the way back. I stay almost level until I'm very close indeed to the runway, then pull back on power a bit and flare. No idle and no full back stick, though. I haven't actually tried that, but from the way the Baron behaves my intuition tells me it wouldn't be suitable. I heard that you run out of elevator authority if you get too slow but that's only a guess... Possibly. I'm usually at least 10 kts above stall speed so I don't really know (or maybe you are not talking about a Baron?). Too bad there isn't some kind of virtual flight instructor network for msfs. You really could use it. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
ID Please - Throttle Quad | Orval Fairbairn | Restoration | 0 | December 17th 05 08:35 PM |
Throttle movement | Max Richter | Naval Aviation | 12 | December 11th 04 11:09 PM |
Engine throttle | Bob Ingraham | Simulators | 13 | December 11th 04 07:17 PM |
Which throttle governer? | Garfiel | Rotorcraft | 1 | December 13th 03 04:30 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
