On Mar 11, 9:44 am, Mxsmanic wrote:
If you're flying the traffic pattern, your ground track should be a perfect rectangle with rounded corners, and in your Baron, your turn from base to final should be completed about 3/4 mile out from the threshold leaving you plenty of time to get stabilized on final. If you turn substantially inside this point, you will have too little time to stabilize your approach, and you should go around. In real life, I would. In the sim, it depends on what I'm trying to practice. The sim gives you the luxury of short-circuiting anything that isn't directly relevant to whatever exercise you've undertaken. In real life, sometimes you get asked to do a 'short approach'. This would be probably the closest to what you're doing in the sim, so if you are looking to real life for validation of what you do in the sim, then there you go.. I have done some wacky, crazy approaches when asked to do a short approach, usually with healthy doses of sideslip.. You can't feel a crosswind in a real plane either. It's the same as in the sim, you just look forward out the window and check to see if the ground is drifting by sideways, then correct for it by turning slightly into the wind, so that you end up tracking exactly along the runway's extended centerline. So much the better, then. I thought it was something you would feel in a real aircraft. I suppose if it's steady you wouldn't notice it. You don't feel it because the air and the ground are not connected.. You have to look at the drift and correct for it. Quite easy to do in practise, easier than trying to explain it :-) |
chris writes:
In real life, sometimes you get asked to do a 'short approach'. This would be probably the closest to what you're doing in the sim, so if you are looking to real life for validation of what you do in the sim, then there you go.. I know I've seen real aircraft do it; I couldn't remember what it was called. Ironically, I'd probably turn it down in real life, as I tend to be extremely prudent. I have done some wacky, crazy approaches when asked to do a short approach, usually with healthy doses of sideslip.. You're braver than I am. You don't feel it because the air and the ground are not connected.. That makes sense. I guess there's no telltale squeal of tires. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Mar 11, 6:34 pm, Mxsmanic wrote:
chris writes: I have done some wacky, crazy approaches when asked to do a short approach, usually with healthy doses of sideslip.. You're braver than I am. A short approach doesn't have to be crazy but some of us like it that way :-) You don't feel it because the air and the ground are not connected.. That makes sense. I guess there's no telltale squeal of tires. There is no tyre noise until you touch down, of course, and you need to look out the window to establish how much you correction you need to apply.. |
An aspect of an expedited approach because of following traffic being
overlooked is to carry more airspeed over the numbers, slow down and touch down close to where you're going to leave the runway. Too often guys is light GA airplanes will land a few hundred feet past the numbers when the turn off is 2500 feet ahead of them. Fly to within a thousand feet, land, and clear the active. On Mar 11, 4:23 am, "chris" wrote: On Mar 11, 6:34 pm, Mxsmanic wrote: chris writes: I have done some wacky, crazy approaches when asked to do a short approach, usually with healthy doses of sideslip.. You're braver than I am. A short approach doesn't have to be crazy but some of us like it that way :-) You don't feel it because the air and the ground are not connected.. That makes sense. I guess there's no telltale squeal of tires. There is no tyre noise until you touch down, of course, and you need to look out the window to establish how much you correction you need to apply.. |
ID Please - Throttle Quad | Orval Fairbairn | Restoration | 0 | December 17th 05 08:35 PM |
Throttle movement | Max Richter | Naval Aviation | 12 | December 11th 04 11:09 PM |
Engine throttle | Bob Ingraham | Simulators | 13 | December 11th 04 07:17 PM |
Which throttle governer? | Garfiel | Rotorcraft | 1 | December 13th 03 04:30 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
