"Andy Hawkins" wrote in message
... Hi, In article , wrote: You land in a crab and the plane will straighten out when it touches down. How does this straightening out occur? Is rudder applied automatically, or are you relyinn on the landing gear bringing the plane into line? Cheers Andy If you touch down just a bit sideways, the center of gravity, being ahead of the main gear, will pull the aircraft in line (assuming nosewheel aircraft). The mass tries to keep going, and the main gear create a drag force behind and to one side of the Cg. That's the advantage of the nosewheel. A tailwheel aircraft, on the other hand, will want to turn around and roll backwards. Which is why you have to pay attention when landing a taildragger. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
ID Please - Throttle Quad | Orval Fairbairn | Restoration | 0 | December 17th 05 08:35 PM |
Throttle movement | Max Richter | Naval Aviation | 12 | December 11th 04 11:09 PM |
Engine throttle | Bob Ingraham | Simulators | 13 | December 11th 04 07:17 PM |
Which throttle governer? | Garfiel | Rotorcraft | 1 | December 13th 03 04:30 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
