![]() But if the hairline crack doesn't break the paint film the oil will still be contained. Besides the oil, weld a boss on a longeron tube end and install a tire valve and pressurize to 100 or so psi pressure during the annual. The pressure should be enough to make the paint film fail and cause leakdown. Find the leak by listening or water/soap. Llama helicopters charge the truss permanently with dry nitrogen and have a pressure gauge that is in view behind the cabin and can be checked on a DI. John Now that is an interesting way of doing it. Just check the pressure on preflight, and you'll know there aren't any cracks if it's still holding pressure. Plus, if charged with an inert gas such as nitrogen, helium, or argon, you also know there will not be any corrosion inside the tube. Don W. |
"Don W" wrote in message
. .. Now that is an interesting way of doing it. Just check the pressure on preflight, and you'll know there aren't any cracks if it's still holding pressure. Well . . . you will know that the gauge pointer hasn't moved. For fire extinguisher classes, I had a demo extinguisher which was cut open so's you could see the interior. The gauge still read in the green. Rich S. |
Rich S. wrote:
"Don W" wrote in message . .. Now that is an interesting way of doing it. Just check the pressure on preflight, and you'll know there aren't any cracks if it's still holding pressure. Well . . . you will know that the gauge pointer hasn't moved. For fire extinguisher classes, I had a demo extinguisher which was cut open so's you could see the interior. The gauge still read in the green. Rich S. It's probably overkill to have a gage reading continuously anyway. The gage would change for some reason and you'd panic and ground your airplane. Better to just hook something up during an annual. John |
Alodine POWDER? | flybynightkarmarepair | Home Built | 3 | May 12th 06 01:18 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 12 | December 24th 04 01:12 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 2 | December 12th 04 08:15 PM |
One coat paint for aluminum? | [email protected] | Home Built | 10 | September 17th 04 07:01 AM |
Tire talc...baby powder? | No Spam | Owning | 12 | August 8th 03 05:03 PM |
