truck + 5th wheel RV + glider trailer ??
Old March 26th 07, 03:43 PM posted to rec.aviation.soaring
Tuno
Default truck + 5th wheel RV + glider trailer ??
Steve,
The crew and I looked at doing this before we bought our motorhome two
years ago. You can't do it, because you have a trailer pulling a
trailer, and you can't get a trailer hitch put on a 5th wheel.
2NO
Old March 26th 07, 07:16 PM posted to rec.aviation.soaring
Steve Koerner
Thanks for the input on the 65 ft limit. I'm thinking that still may
be workable though. The glider trailer is 29 ft and distance from the
nose of my truck to the center of the bed is 15 ft. That would leave
21 ft for RV measured from the center of the fifth wheel aft -- a
smallish RV trailer but not too bad.
The biggest question in my mind is how would this menagerie tow at
highway speed?
Old March 26th 07, 07:40 PM posted to rec.aviation.soaring
highway speed?
I have seen a photo of someone doing what the OP suggested. I believe
the pictures are in the photos section of the 1-26 associations
website.
Old March 26th 07, 08:39 PM posted to rec.aviation.soaring
Steve Koerner
No such pic is presently in the 1-26 association gallery. Lots of
nice 1-26 pictures though.
Old March 26th 07, 07:57 PM posted to rec.aviation.soaring
rustynuts
Steve
Also along with the length law, you must have active brakes on all
trailing
units if more than one trailer. Not just surge brakes but something
like
electric brakes. I think the limit in western states for doubles is
30' per
unit. The longer the power unit's wheel base the better and lighter
trailer
to rear. I'd go with at least 3/4 ton or more.
Russ
highway speed?
Old March 26th 07, 08:48 PM posted to rec.aviation.soaring
Steve Koerner
Russ,
Thank you for that input. Is this rule regarding brakes a national
standard of some sort or is this a rule that pertains to operation in
some partcular states? I wouldn't want to have to mess with my nice
surge brakes on the glider trailer unless I really have to.
Old March 26th 07, 11:01 PM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
"Steve Koerner" wrote in message
Russ,
What you do, is to go to the nearest truck stop - they have book that lists
all of the requirements (lengths, number of trailers, etc) for each state.
It may also be specific as to brakes as well - it won't hurt to ask.
Note: Have you ever tried to back a tandem trailer before?
It can be done, but probably not by you or me.
Geoff
Old March 26th 07, 11:59 PM posted to rec.aviation.soaring
dwrobel
Double and triple trailering is legal in Utah as long as it is under
the 65 ft, and at least double trailering is legal in Idaho, Arizona,
Wyoming, Nevada and for non-resident rigs, in California (apparently
Ca. residents cannot pull two trailers but I can in their state). I
contacted the DMVs of each of these states to find out if it was legal
and was given the go ahead. I have been hauling my 4 ATVs on a
trailer through these states behind my 5th wheel camping trailer for
50,000 miles during the last 6 years. I have trailer brakes on the
5th wheel but not on the ATV trailer. Since the ATV trailer has a
single axle and weighs less than 750 pounds empty, I do not even need
a license on that trailer. I generally set the cruise control at
70-75mph on those sections of road that allow it but if the road is
rough or windy I'll back off of that. The 5th wheel tows like it is
not even there but the back trailer being a tow behind, is not quite
as stable. The stability of a tow behind trailer is somewhat
dependent on how much tougue weight it has so I put the heavier ATVs
on the front. In order for this arrangement to work very well, the
middle trailer has to be much heavier than the back trailer - just
like the truck or car is much heavier than the trailer it pulls. 5th
wheel trailers, on the other hand can be heavier than the pulling
vehicle and still be stable. I have backed the rig up twice, once to
see if I could do it and once to turn around on a dirt road that I
couldn't get through. I do however, prefer the big parking lots to
turn around in.
Old March 27th 07, 12:13 AM posted to rec.aviation.soaring
Udo
turn around in.
I have looked into it as well here in Ontario.
75 feet is legal here. In New York State it is not.
Ontario registered rigs can transit through NY State and other States.
Udo
Old March 27th 07, 12:25 AM posted to rec.aviation.soaring
rustynuts
Russ,
I've spent the last 35 years in the trucking industry, the first 20
pulling doubles in
the western states. First of all you probably don't want to eat that
truck stop food.
Second when you push on the brake pedal and your rear trailer becomes
quite
visable, as in trying to pass you because you don't have a good
breaking
balance on wet or icy roads. Or it is pushing you because the're not
adjusted
up tight enough it's very unnerving. All of the (big) trucks you see
out there have a
trailer hand valve so you can apply trailer only braking. More than
once I've
streightened out a bad situation with a little application of trailer
braking, where
as foot aplication would have caused a jack knife. I always avoided
backing
whenever possible when in doubt walk it out first before you're forced
to break your
set up and drive them out one at a time.
See California Motor Vehicle Ch.3 26301 through 26458 pay special
attention to
26458 c 4 for combinations. My take on this is if you have a surge
brake on these
unit(s) it's legal if your breakaway is funtional.
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
