On Apr 5, 8:34 am, " wrote:
On Apr 4, 8:36 pm, "Johnny Google" wrote: Hi all, I've been looking at the possibilty of buying and owning a 1977 Hawk XP that is very near its 1500 TBO. As I understand it, starting in 1979, the engine TBO went to 2000. What is the difference and can the 2000 TBO engine be put in the 1977 Hawk XP? Or can the changes that make it a 2000 TBO vs 1500 TBO be applied to the enginer during a rebuild? What costs are involved in making this change? What other differences are there between a 1979-1981 Hawk XP and a 1977? Thanks, John Real question is: How is it running? Probability of going past TBO depends a lot on the condition of the cylinders which depends a lot on how often it's been flown and other factors. The other thing that blows the whistle on these IO360 engines is something cracked on the case. I've seen this on turbo Skymasters especially. If it's running OK, who cares where it is relative to TBO? Could easily go past 1500. If it's not running OK, doesn't matter whether it's a KB or not. If you are up in the yellow arc of tbo, you will find that it won't be economical to fix a few bad cylinders and you will be facing TBO when cylinders start to wheeze. I have a hunch it won't make it much past 1500 in any event. You should buy it as if it's run out and you have to major it tommorrow. And then you would upgrade it to a KB. FWIW. Bill Hale A&P- Hide quoted text - - Show quoted text - Bill, Actually, that is exactly what I was trying to make sure I *could* do - my question was geared towards determining if it was possible, how the change works - must you purchase a entirely different engine, or does a particular modification change the engine from a K to a KB, and what costs are involved in going from a K to a KB. (or is it the same costs assuming it is time to overhaul anyway) Thanks, John |
On Apr 5, 9:56 am, "Johnny Google" wrote:
On Apr 5, 8:34 am, " wrote: On Apr 4, 8:36 pm, "Johnny Google" wrote: Hi all, I've been looking at the possibilty of buying and owning a 1977 Hawk XP that is very near its 1500 TBO. As I understand it, starting in 1979, the engine TBO went to 2000. What is the difference and can the 2000 TBO engine be put in the 1977 Hawk XP? Or can the changes that make it a 2000 TBO vs 1500 TBO be applied to the enginer during a rebuild? What costs are involved in making this change? What other differences are there between a 1979-1981 Hawk XP and a 1977? Thanks, John Real question is: How is it running? Probability of going past TBO depends a lot on the condition of the cylinders which depends a lot on how often it's been flown and other factors. The other thing that blows the whistle on these IO360 engines is something cracked on the case. I've seen this on turbo Skymasters especially. If it's running OK, who cares where it is relative to TBO? Could easily go past 1500. If it's not running OK, doesn't matter whether it's a KB or not. If you are up in the yellow arc of tbo, you will find that it won't be economical to fix a few bad cylinders and you will be facing TBO when cylinders start to wheeze. I have a hunch it won't make it much past 1500 in any event. You should buy it as if it's run out and you have to major it tommorrow. And then you would upgrade it to a KB. FWIW. Bill Hale A&P- Hide quoted text - - Show quoted text - Bill, Actually, that is exactly what I was trying to make sure I *could* do - my question was geared towards determining if it was possible, how the change works - must you purchase a entirely different engine, or does a particular modification change the engine from a K to a KB, and what costs are involved in going from a K to a KB. (or is it the same costs assuming it is time to overhaul anyway) Thanks, John- Hide quoted text - - Show quoted text - Also wanted to note I agree that if the engine is running fine, I won't be making this change or overhaul prematurely - just want to know what options I have when I do have to overhaul. |
Johnny Google wrote:
Actually, that is exactly what I was trying to make sure I *could* do - my question was geared towards determining if it was possible, how the change works - must you purchase a entirely different engine, or does a particular modification change the engine from a K to a KB, and what costs are involved in going from a K to a KB. (or is it the same costs assuming it is time to overhaul anyway) It's possible to change an engine from one model to another at overhaul. If the differences are simple, it can be done by an overhaul shop. The devil is in the details, and Continental will be the keeper of the details in this case. The more common option is to swap your old K for a KB at overhaul time. The case and the crankshaft represent the two most expensive parts to replace. It may actually be cheaper to do a swap. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
On Apr 5, 2:54 pm, "JGalban via AviationKB.com" u32749@uwe wrote:
Johnny Google wrote: Actually, that is exactly what I was trying to make sure I *could* do - my question was geared towards determining if it was possible, how the change works - must you purchase a entirely different engine, or does a particular modification change the engine from a K to a KB, and what costs are involved in going from a K to a KB. (or is it the same costs assuming it is time to overhaul anyway) It's possible to change an engine from one model to another at overhaul. If the differences are simple, it can be done by an overhaul shop. The devil is in the details, and Continental will be the keeper of the details in this case. The more common option is to swap your old K for a KB at overhaul time. The case and the crankshaft represent the two most expensive parts to replace. It may actually be cheaper to do a swap. John Galban=====N4BQ (PA28-180) -- Message posted viahttp://www.aviationkb.com Thanks - Does someone have recent / realistic costs associated with swapping a K for a KB at overhaul on a 172 XP? Is it a standard rebuilt engine cost for the KB (if so - what is this cost for this engine) and would get some sort of core or exchange value for the K you are 'swaping' ? Assuming that even if I get another 500 hours out of this 360-K, I would like to know what total costs will be involved in swapping out for a 360-KB? Any one recently gone through this with their XP? Thanks, John |
On 6 Apr 2007 00:31:21 -0700, "Johnny Google"
wrote: Thanks - Does someone have recent / realistic costs associated with swapping a K for a KB at overhaul on a 172 XP? Is it a standard rebuilt engine cost for the KB (if so - what is this cost for this engine) and would get some sort of core or exchange value for the K you are 'swaping' ? If you want real numbers, perhaps you should contact someone in the business of overhauling engines. Unfortunately, there really is no such animal as a "standard overhaul price". The overall condition of an engine that has apparently only had less than 1500 hours of run time in the last 30 years is anybody's guess. Unless it has been short- or long-term corrosion protected in this period of time, the condition is likely to be poor. As others have indicated, this is a 30 year old engine that was subject to a fairly major upgrade 29 years ago and is at/approaching recomended TBO. In reality, it has no real-world value other than maybe being a core engine. Somebody would probably be able to answer some of your questions at one of these facilities (in no particular order): http://www.zephyrengines.com/homepage.html http://www.gnaircraft.com/ http://www.overhaul.com/ http://www.aircraftoverhauls.com/ http://www.lycon.com/ http://www.menaaircraftengines.com/ http://www.mattituck.com/ http://www.firewallforward.com/ http://www.westernskyways.com/ http://www.victor-aviation.com/nav.shtml?company.shtml http://www.airmarkoverhaul.com/ http://www.pennyanaero.com/ http://www.factoryengines.com/ Assuming that even if I get another 500 hours out of this 360-K, I would like to know what total costs will be involved in swapping out for a 360-KB? Any one recently gone through this with their XP? For the most part, an engine change is an engine change is an engine change. The dollars are in the details. Are you going to repair/renew baffling? Repair/replace exhaust components? New hoses? Re-work the engine mount? Some might need a couple more hoses, some might need a few less. Some engine shock mounts are more $$, some are less $$. I am not trying to discourage you, or muddy the waters-the odds of someone posting here that has recently had a 360K converted to a KB and hung on an XP are pretty slim. Honestly, I didn't think there were that many K (as in non-KB) engines still flying around. TC |
On Apr 6, 7:13 am, wrote:
On 6 Apr 2007 00:31:21 -0700, "Johnny Google" wrote: Thanks - Does someone have recent / realistic costs associated with swapping a K for a KB at overhaul on a 172 XP? Is it a standard rebuilt engine cost for the KB (if so - what is this cost for this engine) and would get some sort of core or exchange value for the K you are 'swaping' ? If you want real numbers, perhaps you should contact someone in the business of overhauling engines. Unfortunately, there really is no such animal as a "standard overhaul price". The overall condition of an engine that has apparently only had less than 1500 hours of run time in the last 30 years is anybody's guess. Unless it has been short- or long-term corrosion protected in this period of time, the condition is likely to be poor. As others have indicated, this is a 30 year old engine that was subject to a fairly major upgrade 29 years ago and is at/approaching recomended TBO. In reality, it has no real-world value other than maybe being a core engine. Somebody would probably be able to answer some of your questions at one of these facilities (in no particular order): http://www.zephyrengines.com/homepage.html http://www.gnaircraft.com/ http://www.overhaul.com/ http://www.aircraftoverhauls.com/ http://www.lycon.com/ http://www.menaaircraftengines.com/ http://www.mattituck.com/ http://www.firewallforward.com/ http://www.westernskyways.com/ http://www.victor-aviation.com/nav.shtml?company.shtml http://www.airmarkoverhaul.com/ http://www.pennyanaero.com/ http://www.factoryengines.com/ Assuming that even if I get another 500 hours out of this 360-K, I would like to know what total costs will be involved in swapping out for a 360-KB? Any one recently gone through this with their XP? For the most part, an engine change is an engine change is an engine change. The dollars are in the details. Are you going to repair/renew baffling? Repair/replace exhaust components? New hoses? Re-work the engine mount? Some might need a couple more hoses, some might need a few less. Some engine shock mounts are more $$, some are less $$. I am not trying to discourage you, or muddy the waters-the odds of someone posting here that has recently had a 360K converted to a KB and hung on an XP are pretty slim. Honestly, I didn't think there were that many K (as in non-KB) engines still flying around. TC If you want to upgrade it to a -KB, you should plan on a factory re- man. This will prove to be the only economical approach. Why? Because the factory gets a deal on the expensive pieces required that the overhauler guy doesn't! Another option would be to find a partially runout -KB. Probably more cost effective. Bill H. |
Curtiss Hawk 75 | JDupre5762 | Restoration | 0 | June 22nd 04 01:34 AM |
I have my new Sparrow Hawk | Patrick McLaughlin | Soaring | 36 | May 9th 04 04:37 AM |
Black Hawk down | C.H. | Military Aviation | 0 | November 15th 03 05:31 PM |
Is Hawk 128 "yesterday's jet"? | Urban Fredriksson | Military Aviation | 7 | August 8th 03 07:31 AM |
Hawk 200 questions | Kerry Ferrand | Military Aviation | 14 | July 31st 03 11:14 AM |
