OK, I'm going to ask another fuel tank question.
Old April 7th 07, 06:05 AM posted to rec.aviation.homebuilt
Ernest Christley
Default OK, I'm going to ask another fuel tank question.
Morgans wrote:
"Lou" wrote
A question I've never asked nor have I seen asked.
Can you use Avgas in an auto conversion engine? I'm not
against using avgas so if this can be done I would be interested
in the results.
Yes, generally. If you are going to use an oxygen sensor for fuel (mixture)
control, then there is the problem of the lead fouling the sensor, and
making it nearly useless in a relatively short period of time. Some people
have put a deflector ahead of the sensor to keep from fouling them as fast,
but then they are not doing a very good job at measuring the mixture.
Ed Anderson runs avgas in his rotary powered RV. The lead killing the
oxygen sensor is somewhat of a misnomer, he says. What happens is that
the sensors response rate drops dramatically as it becomes contaminated.
This does make it useless in a car, where the onboard computer uses
the sensor output to maintain a proper mixture; however, if you're just
using the sensor to tune the engine or manually lean at altitude, it's
not much of an issue. It still responds much faster than a human will.
There are always the same problems of lead deposits, but as usual, keeping
things hot help. The largest problems with that are valve deposits, and
since auto engines are generally more tolerant of higher operating
temperatures, it is important to aggressively lean all the time, and also to
not run as rich at full power like you would an air cooled engine, but
appropriately leaned.
Old April 22nd 07, 12:46 AM posted to rec.aviation.homebuilt
Peter Dohm
in the results.
(mixture)
people
fast,
Two experiences auto mechasnics have told me the same thing, so I am
accepting this as pretty good confirmation.
Peter
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 07:56 AM
Anyone had fuel tank air vent icing up? Ronnie Instrument Flight Rules 0 March 1st 06 07:58 PM
Anyone had fuel tank air vent icing up? Jim Macklin Instrument Flight Rules 3 February 28th 06 09:57 PM
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
