IFR in uncontroller airspace
Old April 15th 07, 04:14 PM posted to rec.aviation.piloting
Ron Natalie
Default IFR in uncontroller airspace
Blueskies wrote:
: Of course not, in uncontrolled airspace. But many other rules apply:
: cruise altitudes for direction of flight, minimum altitudes, etc.
: - FChE
I guess I really don't get this. Folks fly below VFR minimums in class G under IFR? Under what 'rules?'
Under IFR rules. You can't fly in conditions below the VFR weather
minimums (legally) except IFR.
This means you must be:
1. Instrument rated.
2. Have a plane with the necessary equipment and
inspections for IFR flight.
3. Maintain the minimum altitudes
4. Pilot must be IFR current.
5. If you can arrive VFR at the destination, you must have an
instrument approach.
Except for takeoffs and landings from airports that don't have
surface areas, practical IFR in uncontrolled airspace is thwarted
by #3 and #5 above in most cases. You can't do enroute below
1000'/2000' (normal/mountainous) and most approaches will start
in controlled airspace even if they don't terminate there.
There's also a (not supported by regulation) legal interpretation
where a guy was strung up where the FAA interpretted it as
reckless and dangerous because he did not have an IFR clearance
at the time he took off to continue his flight into controlled
airspace.
Old April 15th 07, 04:07 PM posted to rec.aviation.piloting
Ron Natalie
Blueskies wrote:
"Ron Natalie" wrote in message ...
: Blueskies wrote:
: The title to this thread should be "IF" in uncontrolled airspace, the "R" makes it an oxymoron...
: All the IFR RULES still apply. The only thing you don't have
: is a clearance.
Isn't a clearance one of the rules?
Having a clearance in CONTROLLED AIRSPACE is one of the rules.
All the other ones: pilot qualifications, aircraft equipment,
minimum altitudes, alternates, fuel reserves, etc... still apply.
Uncontrolled airspace only eliminates the need for a clearance,
not the bulk of the IFR rules.
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
OLC and airspace 5Z Soaring 6 July 30th 05 03:25 AM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 04:46 AM
GPS and airspace Marty from Sunny Florida Owning 5 June 29th 04 02:08 PM
Do I own my airspace? Chief McGee Rotorcraft 17 March 16th 04 01:36 AM
