Slotted Flaps Pitching Moment
Old April 13th 07, 10:59 PM posted to rec.aviation.homebuilt
J.Kahn
Default Slotted Flaps Pitching Moment
Been researching this but can't find a direct answer:
Is the increase in nose down pitching moment from deployment of flaps
any more for a single slotted flap vs a plain flap, all other factors
being the same? If a design that used a plain flap was switched to
slotted while keeping the areas etc, the same, is more tail volume
required to compensate?
John
Old April 14th 07, 12:58 AM posted to rec.aviation.homebuilt
john smith[_2_]
As I understand aerodynamics, the sloted flap is a means of increasing
the wing cord by using less material.
It is the increase in the cord width which allows the center of lift to
move aft, resulting in a pitch down moment.
Old April 14th 07, 12:14 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Fri, 13 Apr 2007 19:58:24 -0400, john smith
for the slotted flap that makes sense.
the position of the lift is an average of all the pressures on the
wing. if you increase the camber by bending down a part of the back of
the wing you change the gas flows which changes the pressure
distributions which moves the resultant back toward the new activity.
a wittman tailwind has a simple flap about 4~5 inches wide which
causes more of a pitch change than a slotted fowler flap on a cessna
150.
I would think that the factors are camber, aerofoil section
characteristics, whether the "tail volume" was already marginal and
how much trim effectiveness there is in your system.
it would probably need to be tested but this should be none too
traumatic because you can pull the flaps off in a hurry if you need
to.
One thing you would need to look at is whether your max flaps speed
changes with the new flaps and whether you have upset the flutter
dynamics of the wing.
Stealth Pilot
Old April 14th 07, 03:16 PM posted to rec.aviation.homebuilt
J.Kahn
150.
to.
Stealth Pilot
Well, as I understand it the slot is simply to energize the upper
boundary layer to keep the flow on top attached at higher angles, same
as a leading edge slat. Now the leading edge slat, when deployed, moves
the CP forward and decreases pitching moment. Does the presence of the
slot in the flap move the overall wing CP forward or aft vs the
unslotted flap at a given angle? This is what I'm having trouble
finding out. I would think that the presence of the slot imcreases the
pressure gradient and moves it more aft than the plain one, so that the
pitching moment is increased.
John
Old April 14th 07, 08:59 PM posted to rec.aviation.homebuilt
john smith[_2_]
AS Stealth Pilot posted, the purpose of the slot is to energize the flow
over the flap.
A better question is, what are the relationships between center of
pressure (CP) and center of lift (CL)?
Do they differ?
Why do they differ?
Under what conditions do they coincide?
Old April 15th 07, 01:41 AM posted to rec.aviation.homebuilt
Peter Dohm
"john smith" wrote in message
over the flap.
Do they differ?
Why do they differ?
There are a lot, if not all, of the old NACA reports online these days on
the NASA Technical Reports Server at:
http://ntrs.larc.nasa.gov/search.jsp?N=279&Ne=25
I got to the following by simply entering the search term: slotted flap
http://ntrs.larc.nasa.gov/search.jsp...matchall&Ntt=s
lotted%2Bflap (If that URL wraps, you may have to cut-and-paste or run the
search again.)
If you don't find the info on NTRS, the next easiest method would probably
be to built a couple of mock-ups and project each of them well outside of a
car at a time when there is no wind; such as is frequently the case in early
morning. (As you may have guessed, I am too lazy and cheap to built a wind
tunnel--and I suspect intuitively that this is the sort of test in which
interference from the floor and ceiling of the tunnel would have a major
influence.)
Peter
(Not an aerodynamicist)
Old April 16th 07, 05:00 PM posted to rec.aviation.homebuilt
over the flap.
Do they differ?
Why do they differ?
CP is the term most often used, implying that it's the same
thing.
As far as pitching moment, there are other considerations
besides CP movement. In the 150 and 172 the nose pitches UP when flaps
are deployed, not down. The downwash off the flaps strikes the
stabilizer and raises the nose, demanding nose-down trim. The position
of the stab is a bit different in other Cessnas like the 180/185 and
the nose pitches down instead.
Dan
A Moment of Thanks. Peter Maus Rotorcraft 1 December 30th 04 08:39 PM
Moment of silence AZSKYBUM Soaring 0 December 23rd 03 04:57 AM
Never dull moment. Lord Struthers Soaring 0 November 3rd 03 05:28 AM
Looking For W&B Using Arm Instead of Moment John T Piloting 13 November 1st 03 08:19 PM
Permit me a moment, please, to say... Robert Perkins Piloting 14 October 31st 03 02:43 PM
