GAO on VH-71 (too heavy); V-22 (better design need); JSF (need knowledge-based approach), etc
Old April 9th 07, 01:36 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Mike[_7_]
Default GAO on VH-71 (too heavy); V-22 (better design need); JSF (need knowledge-based approach), etc
see
from http://www.gao.gov/htext/d07406sp.html or http://www.gao.gov/new.items/d07406sp.pdf
GAO report number GAO-07-406SP entitled 'Defense Acquisitions:
Assessments of Selected Weapon Programs' which was released on March
30, 2007.
This is the accessible text file for GAO report number GAO-07-406SP
entitled 'Defense Acquisitions: Assessments of Selected Weapon
Programs' which was released on March 30, 2007.
Old April 9th 07, 02:05 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Borderline
On Apr 8, 7:36 pm, "Mike" wrote:
see
fromhttp://www.gao.gov/htext/d07406sp.htmlorhttp://www.gao.gov/new.items/d07406sp.pdf
30, 2007.
What a surprise...not really...
Robert
Old April 13th 07, 10:31 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
I wonder how the F-35C slip may influence F/A-18E/F orders. It dropped
from initial 548 aircraft or more to around 460, but now I've heard
the proposal is to increase it again to 494....
Best regards,
Jacek
On 9 Kwi, 02:36, "Mike" wrote:
see
30, 2007.
Old April 15th 07, 06:19 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Pat Flannery
Default GAO on VH-71 (too heavy); V-22 (better design need); JSF (needknowledge-based approach), etc
If they can't fix the weight problem with the V/SOTL version for the
Marines, then this plane is a waste of time.
The whole thing is designed around using that front lift fan in the
Marine version, and if you drop that as an aspect of its design, then
you can build a conventional takeoff/landing aircraft with equal stealth
and superior performance at lower overall price per airframe.
The JSF program resembles the F-111 project; trying to shoehorn to many
mission requirements into a single aircraft.
If all versions of it - Air Force, Navy, and Marine, had the same V/STOL
requirement in their design, then it would make sense.
But what we have now is an aircraft designed for the the Marine V/STOL
requirement which is modified for the Navy and Air Force.
This doesn't make sense.
Total numbers of an aircraft delivered to the Air Force and Navy to meet
their mission requirements shall dwarf those that the Marines need.
The Marines need a Harrier replacement; and neither the Air Force or
Navy use Harriers.
It should be a separate aircraft, optimized to the Marine's needs.
Pat
Old April 17th 07, 11:46 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Not only U.S. Marines, also Royal Navy, but looking what they did with
their Sea Harriers, it is difficult to tell what their next move can
be if serious problems about F-35B arise...
Navy use Harriers.
Pat
PC/PDA based approach plates Nathan Young Instrument Flight Rules 5 January 30th 05 01:15 AM
Commercial Pilot FAA Knowledge Exam - Includes Gleim TestPrep & Commercial Pilot FAA Knowledge Exam book Cecil Chapman Products 1 November 15th 04 04:22 PM
French Missile Based on German Design robert arndt Military Aviation 0 January 6th 04 06:13 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Web-based US approach plates available free Peter R. Owning 1 August 4th 03 03:49 PM
