Power Supply in 98 C182S
Old April 15th 07, 08:11 PM posted to rec.aviation.owning,rec.aviation.piloting
Dan[_1_]
Default Power Supply in 98 C182S
All,
Our club is in the final stages of purchasing a 1998 Cessna 182S.
Much to my dismay, I noticed the lack of a 12-volt cigarette lighter
(or it's 24-volt equivalent) anywhere to be found. (am I just not
looking in the right place?)
What are the options here? How difficult and/or expensive would it be
to have one of these installed? The avionics are relatively new, but I
prefer to use my Garmin 396 for weather, XM, etc. and would really
like to have a place to plug it in.
We'll probably have the plane in the shop soon for a Garmin 430
installation.
Between this issue and the annoying chart clip holder on the yoke, it
sure isn't very compatible with portable GPS equipment.
--Dan
Old April 15th 07, 10:39 PM posted to rec.aviation.owning,rec.aviation.piloting
Newps
My 296 says it operates on 11-35 volts. So plug it in, you're good to go.
Dan wrote:
All,
installation.
--Dan
Old April 16th 07, 12:29 AM posted to rec.aviation.owning,rec.aviation.piloting
Matt Whiting
Dan wrote:
All,
installation.
--Dan
Except he doesn't have a plug ... or at least he can't find one.
Matt
Old April 15th 07, 11:04 PM posted to rec.aviation.owning,rec.aviation.piloting
Scott Skylane
Dan wrote:
All,
/snip/
Dan,
You're right, the late '90's Cessna singles did not have cigarette
lighter jacks installed. There is plenty of room on the panel to
install one (or better yet, two), just like the older models. I've seen
this done on several aircraft.
Happy Flying!
Scott Skylane
Old April 15th 07, 11:53 PM posted to rec.aviation.owning,rec.aviation.piloting
Newps
You can have your mechanic install a cig lighter up under the panel
where you can't see it so you can keep the cord clutter to a minimum.
Scott Skylane wrote:
Dan wrote:
All,
/snip/
Dan,
Happy Flying!
Scott Skylane
Old April 16th 07, 01:02 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
On Sun, 15 Apr 2007 14:04:52 -0800, Scott Skylane
Dan wrote:
All,
/snip/
Dan,
Doesn't it have one of those weird 4 pin ARINC plugs that you need an
adapter for (a-la http://tinyurl.com/2erxr6 ) in the center pedestal?
Old April 16th 07, 01:45 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan wrote:
All,
/snip/
Dan,
I would think that it should, and if it does, the adapter for cigarette
plugs will be a lot cheaper than having one installed.
Jim Pennino
Remove .spam.sux to reply.
Old April 16th 07, 02:19 AM posted to rec.aviation.owning,rec.aviation.piloting
john smith[_2_]
SPORTY'S sells the 12V adaptor that fits the four-pin receptacle.
Old April 16th 07, 06:04 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan[_1_]
On Apr 15, 5:02 pm, Peter Clark
Dan wrote:
All,
/snip/
Dan,
adapter for (a-lahttp://tinyurl.com/2erxr6) in the center pedestal?
Well, I didn't see that, but I was looking on the right side, mainly.
I'll have to check on the center panel. Does anyone know definatively
if late 90s 182s have this connector? I suppose I can look in the
manual... We haven't finalized purchase of the aircraft yet, but
having flown Pipers for about 95% of my flight time to date, the
downward visibility and shade offered by the high wing were definate
pluses.
I thought I wasn't going to like high wing, but it's not that bad
actually...
--Dan
Old April 16th 07, 06:32 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan[_1_]
Dan wrote:
All,
/snip/
Dan,
pluses.
actually...
--Dan- Hide quoted text -
- Show quoted text -
OK, anyone know where I can find an online manual for a 98 182S? : )
--Dan
Power Supply in 98 C182S Dan[_1_] Piloting 12 April 16th 07 06:40 PM
Goddard Cables & Power supply FS Discus 44 Soaring 0 February 1st 07 05:48 PM
Strobe Power Supply Mounting Plate Mike Spera Owning 0 January 1st 07 05:06 PM
B2431 CAN YOU E-MAIL ME ABOUT GYRO POWER SUPPLY Tony Home Built 3 March 8th 06 12:24 AM
WANTING GYRO POWER SUPPLY ???? Tony Home Built 5 March 7th 06 07:17 PM
