Positioning of navs and strobes on the wing tip???
Old April 25th 07, 11:13 PM posted to rec.aviation.homebuilt
Peter Dohm
Default Positioning of navs and strobes on the wing tip???
"Jerry Wass" wrote in message
et...
Jerry Wass wrote:
Peter Dohm wrote:
"Ernest Christley" wrote in message
Michelle P wrote:
DonMorrisey wrote:
Hello group.
Is there a regualtion/description detailing how/where Nav/Strobe/
Position lights get mounted on the wing tip?
I have Aeroflash lights and am ready to cut my fiberglass wing tip
to
mount them but am wondering if there are specific recommendations
other than they should be seen from 360 degrees.
Thanks for the help. Don....
Visibility should be 120 degrees per position.
Left from nose counter clockwise to 120 degrees
Right from nose clockwise to 120 degrees
Rear the remaining 120. Must be visible from above and below as
well. AC
43-13 or Part 23 would have the legal answer.
Michelle
The side lights span 110 degrees. The rear covers 140.
I believe that the rear position light spans something like 180 to 190
degrees.
Peter
Yeah, ya gotta have it span more'n 180° er ya couldn't tell which
direction the observed plane was a goin'..(when it's flyin 90° to your
line of sight)
OOP'S---Logic don work--the BOOK says Red & Green--from dead ahead to
110°toward the stern... White 140° total 70° each side of dead astern...
You KNOW which way it's goin, by the colour of the lite!!
Thanks for the update, I hadn't read it in a long time.
Peter
Old April 29th 07, 03:40 AM posted to rec.aviation.homebuilt
Ernest Christley
line of sight)
Peter
There's also a spec about the maximum amount of overlap that is allowed.
It's not much.
Hershey bar wing vs composite wing - how much drag? Nathan Young Home Built 34 March 29th 07 11:20 PM
Irretating strobes noise John Doe Owning 7 December 22nd 05 01:52 PM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
Strobes Jim Kellett Soaring 18 December 6th 03 12:49 PM
