Transponders Above Class C Airspace
Old May 8th 07, 12:55 AM posted to rec.aviation.soaring
BT
Default Transponders Above Class C Airspace
91.215 (b)(4) states that all aircraft operating above Class B and C
airspace up to 10,000MSL require transponders.
The "glider exemption" described in 91.215(b)(3)(ii) states a glider (no
factory electrical generation system) can operate without a transponder
within 30nm of Class B airspace as long at they operate below the ceiling of
Class B or Class C airspace or 10,000MSL WHICH EVER IS LOWER.
Most ClassB in the US go up to 10,000MSL, so that would be moot, but there
are a few that do not, LAS for example. There is talk of lowering the PHX to
9,000MSL.
The way 91.215(b)(iii) is worded, raises a question. There are many Class C
airspace designations well outside the 30nm ModeC veil associated with Class
B airspace. Can one legally fly above these Class C areas with no
transponder?
BT
"Jim Vincent" wrote in message
A recent discussion on transponders in gliders brought up the issue of a
transponder in Class C airspace. Recognizing that gliders are not required
to have one since they don't have electrical systems, the issue was whether
one is required if you are above towered airspace, such as Class C.
I had been told second hand that a transponder is required within the
lateral boundaries. A friend took the initiative and called the local
FSDO for clarification. While a transponder is not required, it is a good
idea, and it is an especially good idea to contact the tower well
beforehand on the off chance of a descent in to the airspace.
A quick survey: Since this aspect of the regs is somewhat open to
interpretation, is your local FAA person telling you that a transponder is
required? What is your personal policy and understanding of the reg? If
the consensus is that a transponder is required, should associations such
as the SSA for badges and the OLC ding accordingly?
Old May 8th 07, 01:15 AM posted to rec.aviation.soaring
Papa3
9,000MSL.
transponder?
BT
as the SSA for badges and the OLC ding accordingly?- Hide quoted text -
- Show quoted text -
I've overflown Allentown Class C airspace on several occasions without
a transponder. I've spoken with both the FSDO and the Tower Boss, and
their interpretation was that I can do this as long as I complied with
the ATC Authorized Deviations bit which comes near the end of
91.215. In practice, this meant calling them up on the phone on the
day of a planned record flight prior to takeoff. This was followed
with a radio call while still a good 20 miles or so outside their
airspace.
On two occaisions, their "body english" on the radio was along the
lines of "yeah.. whatever." On the third, the guy was all gung-ho and
gave me traffic advisories every few minutes (to the point where it
was almost embarassing). He wished me good luck after clearing their
lateral boundaries and asked me to call in with results !
YMMV.
P3
Old May 8th 07, 01:21 AM posted to rec.aviation.soaring
John Scott
Our club is near a Class C airport. In fact there is a notch in the Class C
airspace, so that it is not above our airport. The top of the Class C
airspace is 10,200' MSL. We shouldn't need transponders because we are 1)
exempt as gliders and 2) above 10,000 MSL when above the Class C. Is the
suggestion here that we should contact Approach when we intend to overfly
the Class C?
John Scott
Old May 8th 07, 01:56 AM posted to rec.aviation.soaring
BT
most interesting location.. what airport that the Class C is so high?
Sounds like Colorado? Please let us know
BT
"John Scott" wrote in message
C airspace, so that it is not above our airport. The top of the Class C
the Class C?
John Scott
Old May 8th 07, 02:32 AM posted to rec.aviation.soaring
John Scott
Colorado Springs
John
Old May 9th 07, 04:08 PM posted to rec.aviation.soaring
Jim Vincent
"Papa3" wrote in message
of
there
to
9,000MSL.
C
Class
transponder?
BT
required
whether
good
is
If
such
airspace.
YMMV.
P3
P3, it was the Allentown airspace I was thinking of. A friend was flying
back from Grimes and overflew the Class C, staying just a few hundred feet
above the airspace. I agree with your recommendation that it would be
prudent to contact ATC before flying over the airspace.
Old May 11th 07, 08:10 AM posted to rec.aviation.soaring
CindyASK
Gents:
For those who are SSA members, you may log in to www.ssa.org, and use
the link
in the upper left corner to go to some artwork illustrating the FAR
91.215 airspace
and requirements. Feel free to down load, print and post the pictures
on a club house wall.
You can also find it through Member News or the Government Liaison
page.
If it keeps folks from blundering, I will have done some good.
And yes, you may always ask for permission for deviations from FARs,
and done so knowledgeably,
most ATC folks are willing to help, as much as they are able.
Overflight of Class C has no
communication requirement, but it does have an equipment requirement
below 10,000 msl.
And, "falling into the top" of Class C with little or no notice to ATC
may be frowned upon.
Personally, I had a tower supervisor tell me that I had no need for a
waiver for a non-TXP glider
for overflight of C below 10k. After I educated him gently, he said
he couldn't
be bothered to write a waiver, and just to not tell them I was
there...... the job title doesn't
assure that they understand regs beyond normal day-to-day uses.
And for Eric G., as often as he and I agree, in this case I personally
disagree.
To avoid heartburn and grumpy FAA folks, install more battery
capacity.
If you are flying around Class A/B/C airspace, you wanted those
systems
for that access, so please supply them well.
A glider pilot shouldn't plan to beg off on no electrons due to being
"slower on course, so I didn't have enough amp hours." To me that
smacks
of "Oh poor me," rather than projecting responsible airmanship. I'm
not throwing
rocks at anyone, just looking at how we view our options.
Cindy B
Old May 12th 07, 06:21 PM posted to rec.aviation.soaring
Eric Greenwell
disagree. To avoid heartburn and grumpy FAA folks, install more battery
capacity. If you are flying around Class A/B/C airspace, you wanted those
systems for that access, so please supply them well.
Sufficient battery capacity is the best answer, but I've seen several
pilots procrastinate on a transponder installation because of their
worries about battery life and the "gotta have it on" regulation. My
intent is to encourage these pilots to install a transponder sooner
rather than later, even if they can't leave it on all the time with
their current battery capacity.
If you think you need a transponder, install it now, even if you haven't
figured out how to get more batteries into the glider. By using it
around the airspace where it's needed, you and others will be safer; in
the meantime, you can deal with the design, installation, and approval
issues (and cost) of another (or larger) battery box.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old May 12th 07, 06:35 PM posted to rec.aviation.soaring
Tony Verhulst
Any LS6 drivers out there with tips on how and where to install a
battery box? There really is no good place as far as I can tell.
Tony V. LS6-b "6N"
Old May 8th 07, 01:20 AM posted to rec.aviation.soaring
Marc Ramsey
Of course, there is a second "glider exemption" in 91.215:
(5) All aircraft except any aircraft which was not originally
certificated with an engine-driven electrical system or which has not
subsequently been certified with such a system installed, balloon, or
glider—
(i) In all airspace of the 48 contiguous states and the District of
Columbia at and above 10,000 feet MSL, excluding the airspace at and
below 2,500 feet above the surface; and
9,000MSL.
transponder?
Reno Class C is surface to 8400 feet MSL, without transponders we
routinely overfly it above 10,000 feet, but do not fly within the
boundaries and below 10,000 feet (or below 8400 feet with a transponder)
without permission from Reno tower. Of course, we are actively
encouraging people to get transponders, not so much for overflights, but
for the critical traffic areas outside of the boundaries of Class C...
Marc
Class A airspace flying_monkey Soaring 66 October 22nd 06 03:38 PM
Class C Airspace Discussion Mike Granby Piloting 48 April 18th 06 12:25 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 02:53 PM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
vfr corridors through class B airspace [email protected] Instrument Flight Rules 26 November 2nd 03 11:28 PM
