My experience mirrors P3's.
Had a flight a few years ago where I had to overfly the El Paso Class C. Phone call the day before, radio contact 10 miles out and all the way across. They were very polite and helpful. I have a new glider coming in a few months and I'm really torn on whether to get a transponder ... my first glider didn't have one, my current one does, but I'm not satisfied it's worth the expense and power drain, which is a real concern on long flights ... by the current regs I do not have the option of leaving it turned off if I have battery power. 2NO |
If you run the transponder off of a seperate battery, you shouldn't have a
problem if it runs dry and the transponder shuts down (unless you are in an area where a transponder is required). If I owned my own glider, a transponder would be close to the top of my priority list. (Murphy's law: If you have one, you won't need it). Mike Schumann "Tuno" wrote in message ups.com... My experience mirrors P3's. Had a flight a few years ago where I had to overfly the El Paso Class C. Phone call the day before, radio contact 10 miles out and all the way across. They were very polite and helpful. I have a new glider coming in a few months and I'm really torn on whether to get a transponder ... my first glider didn't have one, my current one does, but I'm not satisfied it's worth the expense and power drain, which is a real concern on long flights ... by the current regs I do not have the option of leaving it turned off if I have battery power. 2NO -- Posted via a free Usenet account from http://www.teranews.com |
Tuno wrote:
My experience mirrors P3's. Had a flight a few years ago where I had to overfly the El Paso Class C. Phone call the day before, radio contact 10 miles out and all the way across. They were very polite and helpful. I have a new glider coming in a few months and I'm really torn on whether to get a transponder ... my first glider didn't have one, my current one does, but I'm not satisfied it's worth the expense and power drain, which is a real concern on long flights ... by the current regs I do not have the option of leaving it turned off if I have battery power. I know the FAA doesn't expect you to leave your transponder on until you kill the battery, thereby losing the transponder AND your radio. If this is the only regulation you knowingly break, the FAA and your fellow pilots will think you are a saint! Better a transponder part of the time than no transponder at all. If the decision is really causing you heartburn, order the glider with a transponder antenna installed (it's a lot cheaper and easier that way), but no transponder. Put a Zaon MRX transponder detector or similar on top of the glare sheild when you get the glider. It does a good job of alerting a pilot to transponder equipped aircraft, and if you later decide you want that transponder after all, the MRX still continue to alert you, a job a transponder doesn't do. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Class A airspace | flying_monkey | Soaring | 66 | October 22nd 06 03:38 PM |
Class C Airspace Discussion | Mike Granby | Piloting | 48 | April 18th 06 12:25 AM |
Meigs Class D Airspace | Defly | Instrument Flight Rules | 0 | July 19th 04 02:53 PM |
Tower with only Class G Airspace | Jeff Saylor | Piloting | 8 | May 10th 04 09:53 PM |
vfr corridors through class B airspace | [email protected] | Instrument Flight Rules | 26 | November 2nd 03 11:28 PM |
