Gasohol
Old May 31st 07, 07:53 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gig 601XL Builder
Default Gasohol
Robert M. Gary wrote:
On May 31, 11:22 am, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote:
Ken Finney wrote:
IF I ever get a plane, all these silly fuel issues would be a real
irritant. I haven't been paying much attention to the new diesel
aircraft engines becoming available. Since I should be making my
own biodiesel by the end of this Summer (for something less than 45
cents a gallon), are any of the new diesels in the O-200/Rotax 912
class?
You'll never get an STC to put it in a certified aircraft. Better
start thinking experimental.
Actually there is a company with an STC for biodiesel. They have a
C-172 at Sacramento City College that if fully STC'd on biodiesel
rigtht now. If you really want give these guys a call
http://www.do.losrios.cc.ca.us/scc/spring/aviation.htm
-Robert
Link is broken. I'm sure it is from the 10s of 1000s of folks wanting to buy
that STC.
Old May 31st 07, 08:02 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Steve Foley
Default Gasohol
"Al G" wrote in message
What do you grow to make biodiesel?
Al G
Wild wood flower grew down on the farm, but we never knew what it was
called......
Old May 31st 07, 08:03 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Cubdriver
Default Gasohol
On Wed, 30 May 2007 20:13:12 -0400, "Blueskies"
Jay, where do you fill the grape from and how do you know there is no evil alcohol in it?
Hampton Airport in SE New Hampshire sells straight mogas with no
additives. They buy it by the tankload at the terminal in Portland ME
before the bad stuff goes in.
Blue skies! -- Dan Ford
Claire Chennault and His American Volunteers, 1941-1942
forthcoming from HarperCollins www.flyingtigersbook.com
Old May 31st 07, 08:17 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Ken Finney
Default Gasohol
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
aircraft engines becoming available. Since I should be making my own
biodiesel by the end of this Summer (for something less than 45 cents
a gallon), are any of the new diesels in the O-200/Rotax 912 class?
You'll never get an STC to put it in a certified aircraft. Better start
I already am, but there an STC for diesels in 172s.
Old May 31st 07, 08:47 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
NW_Pilot
Default Gasohol
On May 30, 9:32 pm, "Montblack" Y4_NOT!...
("Blueskies" wrote)
evil
alcohol in it?
In the Twin Cities (St Paul / Mpls) the pumps with NO ethanol are marked
special. About 1 in 50 stations has such a pump - and it's usually 93
Premium ...Non-Oxy.
Can I have some shipped out to California? I'm tired of having to
drain my lawn mower and edger after every mowing and having to throw
out the gas in my cans every 30 days. The mower shops are booked up 3
months out cleaning the gook out of carbs.
-Robert
Lawnmower carbs are simple to clean!!!!! I run Avgas in mine Never a
Problem!!!!
Old May 31st 07, 09:16 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gig 601XL Builder
Default Gasohol
class?
Diesels and diesels running Freedom Fry grease are going to require two very
different STCs. Robert posted a link to a outfit with a Biodiesel STC but I
couldn't get the link to work.
Old May 31st 07, 09:17 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gig 601XL Builder
Default Gasohol
Al G
called......
.....Some called it was a flower and some called it a weed...
  #28
Old May 31st 07, 09:45 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
RST Engineering
Default Gasohol
The leftover sticks, stems, and seeds ...
"No sticks, no stones, no stems, no seeds
Acapulco Gold is badass weed."
There are only 10 kinds of people in the world.
Those who count in binary and those who don't
  #29
Old May 31st 07, 10:30 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Jay Honeck
Default Gasohol
Tell the truth Jay. Is it because a 1/2 or full tablet won't fit in the Coke
bottle you are using?
Actually, we use a genuine AOPA coffee mug for our testing...
Really, it doesn't matter how big the piece is -- if it fizzes, you've
got junk gas. It's only got to be big enough to see at the bottom of
the mug.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #30
Old May 31st 07, 10:52 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default Gasohol
"Ken Finney" wrote in message
clare at snyder.on.ca wrote in message
On Thu, 31 May 2007 05:11:27 GMT, tony roberts
Is it true that there is no longer any requirement to label gasoline
contaminated with alcohol?
Worse.
I read that, starting in 2007, in some places, California and some
Canadian Provinces included, it is regulated that all gasoline sold
must
contain at least 5% alcohol/ethanol.
Tony
Here in Ontario I was told not all gasoline must have 5% alky, but 5%
of all fuel sold must be alky - so 50% of all fuel sold being E10
satisfies the requirement. In practice, virtually all 87 octane will
be e10. Premium 91 will (from some companies, at least) be E0, making
the blended 89 E5. Since significantly over half the gasoline sold in
Ontario is 87 octane, this would excede the requirements. - Just from
what I've been told, but you can never trust the elected idiots, or
worse yet the beurocrats
biodiesel by the end of this Summer (for something less than 45 cents a
Relatives that own restuarants and have to pay to dispose of waste fryer
oil!
You grow relatives?
Al G
Gasohol Blueskies Piloting 240 July 6th 07 12:42 AM
Gasohol Blueskies Owning 233 June 30th 07 03:50 AM
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
