"Maxwell" wrote in message ... It is correct. AC 90-66 clairifys it very well, and 91.113 is not in conflict. What do you believe AC 90-66A clarifies? Per AC 90-66. 7f . Position reports on CTAF should include distance and direction from the airport. It doesn't say reports should be given in miles, it says position reports on the CTAF should include distance and direction from the airport. Announcing position over a known fix provides distance and direction and is far more reliable than an estimate of distance. Yep! No conflict. It's your position that "aircraft flying a full pattern do have the right of way." FAR 91.113(g) states that aircraft on final have the right of way. I'd call that conflict. Correct. But an instrument "approach" is an approach, not an instrument "final". FAR 91.113 is found among the general flight rules, it does not distinguish between VFR and IFR operations. Aircraft on final have the right-of-way, it does not matter how they came to be on final. |
"Steven P. McNicoll" wrote in message hlink.net... "Maxwell" wrote in message ... It is correct. AC 90-66 clairifys it very well, and 91.113 is not in conflict. What do you believe AC 90-66A clarifies? That aircraft in the pattern have the right of way. You know, the part you snipped. Per AC 90-66. 7f . Position reports on CTAF should include distance and direction from the airport. It doesn't say reports should be given in miles, it says position reports on the CTAF should include distance and direction from the airport. Announcing position over a known fix provides distance and direction and is far more reliable than an estimate of distance. IFR fixes provide zero informaiton to a VFR pilot. Yep! No conflict. It's your position that "aircraft flying a full pattern do have the right of way." FAR 91.113(g) states that aircraft on final have the right of way. I'd call that conflict. Only because you wish to ignore the FAA recommendations in AC 90-66. Aircraft entering on a straight in approach should not disrupt traffic in the pattern. Correct. But an instrument "approach" is an approach, not an instrument "final". FAR 91.113 is found among the general flight rules, it does not distinguish between VFR and IFR operations. Aircraft on final have the right-of-way, it does not matter how they came to be on final. AC 90-66 is crystal clear, you just don't happen to like it. |
"Maxwell" wrote in message ... That aircraft in the pattern have the right of way. You know, the part you snipped. AC 90-66A does not indicate that aircraft in the pattern have the right-of-way over aircraft on final. IFR fixes provide zero informaiton to a VFR pilot. Is bad information better than no information? Only because you wish to ignore the FAA recommendations in AC 90-66. Aircraft entering on a straight in approach should not disrupt traffic in the pattern. I'll ignore all recommendations that are discourteous , reduce safety, and are inconsistent with the FARs. Everybody should. |
"Steven P. McNicoll" wrote in message ink.net... "Maxwell" wrote in message ... That aircraft in the pattern have the right of way. You know, the part you snipped. AC 90-66A does not indicate that aircraft in the pattern have the right-of-way over aircraft on final. It does indeed, you just don't happen to like it. IFR fixes provide zero informaiton to a VFR pilot. Is bad information better than no information? Only because you wish to ignore the FAA recommendations in AC 90-66. Aircraft entering on a straight in approach should not disrupt traffic in the pattern. I'll ignore all recommendations that are discourteous , reduce safety, and are inconsistent with the FARs. Everybody should. They are none of the above, and nobody should. If you think you are above following the recommended procedures of the FAA, you are simply unsafe. But go ahead, as we can be certain you will. Someday, you or some other IR cowboy like you, will kill someone, and perhaps the FAA with firm things up a bit. |
Often it is. IT depends on how bad the information is. "five miles northeast" when the aircraft is really five point six miles east north east is "bad information". But I'll find him. Jose -- There are two kinds of people in the world. Those that just want to know what button to push, and those that want to know what happens when they push the button. for Email, make the obvious change in the address. |
| Thread Tools | |
| Display Modes | |
| Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 11:55 PM |
| "Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 05:36 PM |
| A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 09:39 PM |
| Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 09:19 PM |
| Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 03:43 PM |
