Flight download
Old June 19th 07, 02:30 PM posted to rec.aviation.soaring
Steve Freeman
Default Flight download
A PDA sounds like a reasonable solution. Do you know if a Palm will
work. I have gone through all of the Cambridge Aero pages on their
website and cannot find any links to software to use to download the
data. Any suggestions?
Old June 19th 07, 04:11 PM posted to rec.aviation.soaring
rromanATfrontiernetDOTnet
You can use "SoarPilot" with a Palm, it's free and available at:
http://www.soaringpilot.org/. I use it with a Cambridge 302A and a
Palm Tungsten T. I have not used it with a GPSNAV but according to the
Soar Pilot documents it will do what you want and more.
Old June 19th 07, 10:01 PM posted to rec.aviation.soaring
Philip Plane
You can use soaringpilot with a Palm. http://www.soaringpilot.org/
For the built in option, check out what the Ozflarm guys are building:
http://www.rf-developments.com/index.php
Look for the Flarm-Nav. It supports connecting to a Cambridge 20 and
has a USB port for offloading the logs.
Philip Plane _____
Glider pilots have no visible means of support
AA77 9/11 Pentagon - Flight Data DOWNLOAD link [email protected] Naval Aviation 0 June 5th 07 08:10 AM
Using a Pocket PC to download Themi flight logs Paul Remde Soaring 5 September 14th 04 07:29 AM
Download Thijs Wolters Simulators 26 June 24th 04 03:36 PM
Lazair in flight movies to download web Home Built 0 March 11th 04 02:36 AM
Cambridge 302 problem: "Could not get FAT.(A)" while trying to download flight logs Jason Armistead Soaring 5 July 13th 03 02:36 PM
