Removing Narco Radios
Old June 27th 07, 08:19 PM posted to rec.aviation.owning
Ross
Default Removing Narco Radios
Steve - KDMW wrote:
I know to remove a Narco radio (Com 810) there is a hole and you
insert a key... kind of like opening a CD-ROM tray with it powered
off. So, my question is, if I don't have this key, what makes a good
substitute? I tried using a 2" jewelers phillips screwdriver but it
apparently wasn't long enough. Is it just a matter of getting
something longer or is there a special shape to this key?
Steve
KDMW
I do not know about he Com 810, but on the MK 12Ds it is just a stiff
pin that is inserted into the hole to move the catches out of the way
and let the radio slide out. One of mine is a little sticky and you
havea to have it in just right. The other one is no problem.
Regards, Ross
C-172F 180HP
KSWI
Old June 27th 07, 10:48 PM posted to rec.aviation.owning
JB
Steve
KDMW
Regards, Ross
C-172F 180HP
KSWI
For the Mark12D (or D+), a piece of coat hanger works perfectly!
Bend the end 90d so it doesn't go into your wrist! :-)
--Jeff
Removing RTV John Home Built 6 October 31st 06 10:07 PM
Removing Ethanol from Gas? Jay Honeck Piloting 67 August 16th 06 03:29 PM
Removing Fabric Michael Horowitz Home Built 3 August 15th 05 11:25 AM
Removing decals [email protected] Owning 8 August 10th 05 03:55 AM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
