Removing Fabric
Old August 11th 05, 11:12 AM
Michael Horowitz
Default Removing Fabric
When you remove fabric from a tube fuselage, the part that is glued
down will be like concrete. I know I dare not scrape for fear of
scratching the tubing.
How do you soften/remove the remaining fabric and glue residue? - Mike
Old August 11th 05, 12:19 PM
Scott
MEK?
Scott
Old August 12th 05, 03:04 AM
Morgans
"Michael Horowitz" wrote in message
Since you are removing fabric, is it safe to say you will be stripping the
frame and repainting? If you are doing the whole thing, it would make sense
to inspect it, repair and paint, right? In that case, sandblast, or
beadblast.
If you are doing a small area, MEK will dissolve stink from sh*t. Watch
prolonged exposure, and protect against skin absorbing the stuff, and
breathing the fumes. Exposure is cumulative, and bad things happen.
If you already knew that, sorry for you seeing it all written again. ;-)
Old August 15th 05, 11:25 AM
Michael Horowitz
Nope; all fine - Mike
beadblast.
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Fabric repair D.A.L Home Built 0 April 27th 04 07:17 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
Fabric Work Doug Home Built 9 January 26th 04 03:31 AM
Need to learn dope and fabric work David Hill Restoration 5 October 9th 03 01:52 AM
