flaps
Old July 10th 07, 09:49 PM posted to rec.aviation.owning,rec.aviation.piloting
Kobra[_3_]
Default flaps
airworthy condition.
(b) The pilot in command of a civil aircraft is responsible for
determining whether that aircraft is in condition for safe flight.
Exercising my PIC privilege, I guess I determined that the aircraft was
airworthy.
Roy Smith wrote:
10 kts too fast over the threshold is pretty significant. I don't fly the
177RG, but I found a checklist on the net that lists normal landing speeds
at 60-70 kts and Vfe (top of the white arc, which is what you said you
were
doing on final) as 95. That's 25-35 kts too fast to land. I'm amazed you
managed to get it stopped in 3000 feet. In fact, I can't believe you were
really going that fast over the threshold, it's just not possible.
I probably wasn't going that fast (95 KIAS). By the time I reached the
threshold I was trimming the nose up and had the power at idle. I was
probably at 90 MPH or 77 KIAS at that point. Normally I cross the fence at
70 MPH or 61 KIAS.
Roy Smith wrote:
Then you should have gone around. Plan every approach to be a go-around,
and only make the decision to land when you get to the threshold and
everything is good
I was very ready to go-around, but the plane touched down well and I knew
from the remaining distance that heavy braking would stop the plane in time.
I landed on 31 and exited off on the second to last exit. It appears from
the diagram that I had over a 1000 feet remaining. The runway is actually
3204 feet, so it wasn't as short as I first described.
http://204.108.4.16/d-tpp/0707/06425VGB.PDF
Roy Smith wrote:
The pondering should have happened before you took off.
Roy, what you said is very true! I am embarrassed about two things. One
that I didn't notice the flaps didn't come down at JGG. If I ever read
someone else's account of this and they said they didn't know the flaps
stayed up I would have thought they were brain dead and should never be
behind a yoke again. But let me tell you...it can happen. If you're busy
talking to traffic, looking for traffic, watching the two planes ready to
take the runway, configuring the airplane for landing, doing your before
landing checklist, flying the plane, etc. It can happen. Especially after
750 hours and setting the flaps in increments about 1200 times with never so
much as a hiccup, one can become easily complacent. So, please no 'holier
than thou' comments, such as Kontiki posted.
kontiki wrote:
As far as why you didn't notice that your flaps were
not working... well... that is disturbing. I notice
*every* little sound, motion, vibration or whatever in
my airplane.
You better knock wood. You speak boldly my friend, and if I might add, a
little cocky. Cocky is disturbing and kills more pilots, I'm sure, than not
noticing flap deployment. If *I* can teach *you* anything, it's that you
CAN miss a little sound, motion, vibration or whatever in your airplane.
Kobra
On Jul 10, 10:00 am, "Al G" wrote:
"Roy Smith" wrote in message
"Kobra" wrote:
snip
From a strictly legal point of view, if you knew the flaps were broken,
plane was not airworthy.
Cite?
Al G
For Americans:
Sec. 91.7
Civil aircraft airworthiness.
(a) No person may operate a civil aircraft unless it is in an
determining whether that aircraft is in condition for safe flight. The
pilot in command shall discontinue the flight when unairworthy
mechanical, electrical, or structural conditions occur.
For Canadians:
Unserviceable and Removed Equipment - General
605.08 (1) Notwithstanding subsection (2) and Sections 605.09 and
605.10, no person shall conduct a take-off in an aircraft that has
equipment that is not serviceable or from which equipment has been
removed if, in the opinion of the pilot-in-command, aviation safety is
affected.
(2) Notwithstanding Sections 605.09 and 605.10, a person may conduct a
take-off in an aircraft that has equipment that is not serviceable or
from which equipment has been removed where the aircraft is operated
in accordance with the conditions of a flight permit that has been
issued specifically for that purpose.
See, both systems leave it up to the pilot to determine
airworthiness. But the Inspector's opinion may differ considerably
from the pilot's, and legal trouble may arise. I know of plenty of
pilots who would fly an airplane that I wouldn't, mostly because I'm
older, have been doing this for enough years, and have had a couple of
engine failures and some systems failures. A flap system failure, for
instance, might leave you with retracted flaps; you take off, get to
the destination, forget that the flaps don't work or decide to see if
they're now working, and find that they extend. Good. Now the approach
gets botched up or someone taxis out in front of you and so you go
around, finding now that the flaps won't retract and you can't climb.
Now what? Was aviation saftey affected? The accident will prove it.
These electric flaps can do this; they've done it to our 172s. When
they give the first hint of trouble the airplane is grounded.
Dan
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
Flaps on take-off and landing Mxsmanic Piloting 397 September 22nd 06 09:02 AM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
