On Jul 10, 3:38 pm, Jay Honeck wrote:
Spend an hour or two landing on the numbers with the stall horn squalling. It's funny how much easier this was to do when I was renting airplanes. Heck, I'd routinely drag it in at minimum forward air speed and plunk it on the numbers, just to see how short I could land. When you own an aircraft -- especially one with a big, heavy 6- cylinder engine that is slightly nose-heavy -- you think twice before "practicing" such things. Tires, struts, brakes, firewalls, props, and engines all become HUGE impediments to "practicing" landings with the stall horn squalling, since you're paying for them all. Jay, I fly my own plane the same way that I flew rental planes. Every so often, Rick and I would try to do some basic maneuvers such as slow flight, steep turns, stalls, soft and short field landings. We have the tires and brakes replaced about every 250 or so hours. I have no ideas how much money we would have saved if we had 'babied' our plane. IMHO, being proficient at short field landings may save my skin someday and no amount of money is worth my life. Hai Longworth |
so often, Rick and I would try to do some basic maneuvers such as slow flight, steep turns, stalls, soft and short field landings. We have the tires and brakes replaced about every 250 or so hours. I have no ideas how much money we would have saved if we had 'babied' our plane. IMHO, being proficient at short field landings may save my skin someday and no amount of money is worth my life. Oh, we practice all the other stuff -- but short-short-short field landings are NOT one of them. Botching a power-off, let's-plant-it-on- the-numbers landing is just too potentially expensive, since Atlas' nose will slam down like Thor's hammer if you let him get too slow. Which isn't to say we shy away from short fields. We routinely fly into 2200 foot grass strips, so we're fairly proficient at it. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: Which isn't to say we shy away from short fields. We routinely fly into 2200 foot grass strips, so we're fairly proficient at it. You should have no problem using a strip half that length with two of you on board. Is your nosewheel/strut/firewall that delicate? That's not Pipers reputation, that's Cessna's. Piper's rep is building planes that are overweight, not fragile. |
![]() " You should have no problem using a strip half that length with two of you on board. Is your nosewheel/strut/firewall that delicate? That's not Pipers reputation, that's Cessna's. Piper's rep is building planes that are overweight, not fragile. No. The Cherokees have MUCH more fragile landing gear. Not only that but they are pushed through the wing so that repair is impractical. You'll NEVER see a Cherokee SIX with 30,000 hours on it, like most Cessna 207s in Alaska. Karl |
Longworth wrote:
I fly my own plane the same way that I flew rental planes. Every so often, Rick and I would try to do some basic maneuvers such as slow flight, steep turns, stalls, soft and short field landings. We have the tires and brakes replaced about every 250 or so hours. I have no ideas how much money we would have saved if we had 'babied' our plane. IMHO, being proficient at short field landings may save my skin someday and no amount of money is worth my life. Hai Longworth Couldn't have said it better myself. |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
