![]() wrote in message oups.com... On Jul 10, 10:00 am, "Al G" wrote: "Roy Smith" wrote in message ... "Kobra" wrote: snip From a strictly legal point of view, if you knew the flaps were broken, the plane was not airworthy. Cite? Al G For Americans: Sec. 91.7 Civil aircraft airworthiness. (a) No person may operate a civil aircraft unless it is in an airworthy condition. (b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur. For Canadians: snip... See, both systems leave it up to the pilot to determine airworthiness. But the Inspector's opinion may differ considerably from the pilot's, and legal trouble may arise. I know of plenty of pilots who would fly an airplane that I wouldn't, mostly because I'm older, have been doing this for enough years, and have had a couple of engine failures and some systems failures. A flap system failure, for instance, might leave you with retracted flaps; you take off, get to the destination, forget that the flaps don't work or decide to see if they're now working, and find that they extend. Good. Now the approach gets botched up or someone taxis out in front of you and so you go around, finding now that the flaps won't retract and you can't climb. Now what? Was aviation saftey affected? The accident will prove it. These electric flaps can do this; they've done it to our 172s. When they give the first hint of trouble the airplane is grounded. Dan Ok, IMHO, inoperative flaps on a C-172 do not in any way render said aircraft un-airworthy. This airplane can be operated safely without flaps. I may limit myself to runways longer than 800', but un-airworthy? They are not recommended for takeoff, optional for landing, and not used enroute. Now if it were a Lear... Al G CFIAMI 2069297 |
aircraft un-airworthy. This airplane can be operated safely without flaps. I may limit myself to runways longer than 800', but un-airworthy? They are not recommended for Al, I agree that inoperative flaps do not render certain aircraft unairworthy. During my primary training, one day the C150 flaps stopped to operate due to a weak battery. The chief instructor who was also an AP and DE told me that I should go out and practice landings without flaps. I had great fun that day practicing slipping to see how short that I could land without 40 degrees flaps. Hai Longworth |
On Tue, 10 Jul 2007 15:15:16 -0700, Longworth
wrote: Ok, IMHO, inoperative flaps on a C-172 do not in any way render said aircraft un-airworthy. This airplane can be operated safely without flaps. I may limit myself to runways longer than 800', but un-airworthy? They are not recommended for Al, I agree that inoperative flaps do not render certain aircraft unairworthy. During my primary training, one day the C150 flaps stopped to operate due to a weak battery. The chief instructor who was also an AP and DE told me that I should go out and practice landings without flaps. I had great fun that day practicing slipping to see how short that I could land without 40 degrees flaps. FWIW, the latest Cessna 182T POH shows the flap motor and indicating system as required in the KOEL for day/night/ifr/vfr. If I read that correctly, technically departing with the flaps known inop in one without a special airworthiness certificate would be a violation.... |
![]() "Peter Clark" wrote in message ... On Tue, 10 Jul 2007 15:15:16 -0700, Longworth wrote: Ok, IMHO, inoperative flaps on a C-172 do not in any way render said aircraft un-airworthy. This airplane can be operated safely without flaps. I may limit myself to runways longer than 800', but un-airworthy? They are not recommended for Al, I agree that inoperative flaps do not render certain aircraft unairworthy. During my primary training, one day the C150 flaps stopped to operate due to a weak battery. The chief instructor who was also an AP and DE told me that I should go out and practice landings without flaps. I had great fun that day practicing slipping to see how short that I could land without 40 degrees flaps. FWIW, the latest Cessna 182T POH shows the flap motor and indicating system as required in the KOEL for day/night/ifr/vfr. If I read that correctly, technically departing with the flaps known inop in one without a special airworthiness certificate would be a violation.... I would go along with that, depending on the operation. It may be that a steep instrument approach is easier with flaps, and then I would insist they work. The 182 is also a bit heavier than the 172 and the flaps help slow the touchdown. Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. Maybe I'm just not as intimidated by them as I used to be. I have flown the '66 172 I rent without flaps, and would do it again. KOEL=?? As a 135 pilot I had a MEL(Minimum Equipt List) for each multi-engine aircraft I flew. I don't believe there is such a thing for a part 91 single engine pilot. In most cases, if something were inoperative, that imposed limits on your flight, but did not cancel the flight. I would not consider the failure of a light bulb to be an airworthiness item, unless night flight was planned. What if your comm radio was inoperative? Non-airworthy? Many aircraft have no radio, just like many aircraft have no flaps. Al G |
Al G wrote:
Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. It is up to you to decide *while adhering to the FARs*, I think you're missing that point. Hilton |
![]() "Hilton" wrote in message t... Al G wrote: Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. It is up to you to decide *while adhering to the FARs*, I think you're missing that point. Hilton (b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur Nothing in the "regs" says I have to use flaps in a C172. Al G |
Maybe not, you don't have to USE them..........but they must be operable.
Karl "Al G" wrote in message ... "Hilton" wrote in message t... Al G wrote: Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. It is up to you to decide *while adhering to the FARs*, I think you're missing that point. Hilton (b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur Nothing in the "regs" says I have to use flaps in a C172. Al G |
On Tue, 10 Jul 2007 16:02:51 -0700, "Al G"
wrote: FWIW, the latest Cessna 182T POH shows the flap motor and indicating system as required in the KOEL for day/night/ifr/vfr. If I read that correctly, technically departing with the flaps known inop in one without a special airworthiness certificate would be a violation.... I would go along with that, depending on the operation. It may be that a steep instrument approach is easier with flaps, and then I would insist they work. The 182 is also a bit heavier than the 172 and the flaps help slow the touchdown. Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. Maybe I'm just not as intimidated by them as I used to be. I have flown the '66 172 I rent without flaps, and would do it again. KOEL=?? Kinds Of Operations Equipment List. It's contained in Section 2 of the POH (AKA Operating Limits) and is prefaced: "The Cessna 182T Nav III airplane is approved for day and night, VFR and IFR operations. Flight into known-icing conditions is prohibited. The minimum equipment for approved operatons required under the Operating Rules are defined by 14 CFR Part 91 and 14 CFR Part 135, as applicable. The following Kinds of Operations Equipment List (KOEL) identifies the equipment required to be operational for airplane airworthiness in the listed kind of operations." Basically, the lawyers have set it up so that Nav III aircraft have stricter limits on what equipment is required than in the older aircraft that you're used to by creating a KOEL (effectively a MEL). The way it was explained to me is that just like a MEL, in these ones (and I'm pretty sure the 172 Nav III has it as well but don't have a POH or IM handy) since the flap motor and indicator are listed as required by the table in the limitations section, they have to be working or you're not in fact airworthy - regardless of the operation. The POH has effectively removed the decision from you in an aircraft with a MEL or KOEL. |
![]() "Peter Clark" wrote in message ... On Tue, 10 Jul 2007 16:02:51 -0700, "Al G" wrote: FWIW, the latest Cessna 182T POH shows the flap motor and indicating system as required in the KOEL for day/night/ifr/vfr. If I read that correctly, technically departing with the flaps known inop in one without a special airworthiness certificate would be a violation.... I would go along with that, depending on the operation. It may be that a steep instrument approach is easier with flaps, and then I would insist they work. The 182 is also a bit heavier than the 172 and the flaps help slow the touchdown. Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. Maybe I'm just not as intimidated by them as I used to be. I have flown the '66 172 I rent without flaps, and would do it again. KOEL=?? Kinds Of Operations Equipment List. It's contained in Section 2 of the POH (AKA Operating Limits) and is prefaced: "The Cessna 182T Nav III airplane is approved for day and night, VFR and IFR operations. Flight into known-icing conditions is prohibited. The minimum equipment for approved operatons required under the Operating Rules are defined by 14 CFR Part 91 and 14 CFR Part 135, as applicable. The following Kinds of Operations Equipment List (KOEL) identifies the equipment required to be operational for airplane airworthiness in the listed kind of operations." Basically, the lawyers have set it up so that Nav III aircraft have stricter limits on what equipment is required than in the older aircraft that you're used to by creating a KOEL (effectively a MEL). The way it was explained to me is that just like a MEL, in these ones (and I'm pretty sure the 172 Nav III has it as well but don't have a POH or IM handy) since the flap motor and indicator are listed as required by the table in the limitations section, they have to be working or you're not in fact airworthy - regardless of the operation. The POH has effectively removed the decision from you in an aircraft with a MEL or KOEL. So if the flap switch is inop, you're good to go? Al G |
On Tue, 10 Jul 2007 16:40:28 -0700, "Al G"
wrote: Basically, the lawyers have set it up so that Nav III aircraft have stricter limits on what equipment is required than in the older aircraft that you're used to by creating a KOEL (effectively a MEL). The way it was explained to me is that just like a MEL, in these ones (and I'm pretty sure the 172 Nav III has it as well but don't have a POH or IM handy) since the flap motor and indicator are listed as required by the table in the limitations section, they have to be working or you're not in fact airworthy - regardless of the operation. The POH has effectively removed the decision from you in an aircraft with a MEL or KOEL. So if the flap switch is inop, you're good to go? If you can somehow prove it's the switch and not the motor without being an A&P and re-rigging the electrical wiring to show the motor and indicator are both working, I guess. The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
