flaps
Old July 10th 07, 11:35 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
Default flaps
On Tue, 10 Jul 2007 15:15:16 -0700, Longworth
Ok, IMHO, inoperative flaps on a C-172 do not in any way render said
aircraft un-airworthy.
This airplane can be operated safely without flaps. I may limit myself to
runways longer than 800', but un-airworthy? They are not recommended for
Al,
I agree that inoperative flaps do not render certain aircraft
unairworthy. During my primary training, one day the C150 flaps
stopped to operate due to a weak battery. The chief instructor who
was also an AP and DE told me that I should go out and practice
landings without flaps. I had great fun that day practicing slipping
to see how short that I could land without 40 degrees flaps.
FWIW, the latest Cessna 182T POH shows the flap motor and indicating
system as required in the KOEL for day/night/ifr/vfr. If I read that
correctly, technically departing with the flaps known inop in one
without a special airworthiness certificate would be a violation....
Old July 11th 07, 12:02 AM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default flaps
"Peter Clark" wrote in message
to
Al,
I would go along with that, depending on the operation. It may be that a
steep instrument approach is easier with flaps, and then I would insist they
work. The 182 is also a bit heavier
than the 172 and the flaps help slow the touchdown. Never the less, it is
left to me to decide,
and for a 172 I stand by my statement, even to a FSDO. Maybe I'm just not as
intimidated by them as I used to be. I have flown the '66 172 I rent without
flaps, and would do it again.
KOEL=??
As a 135 pilot I had a MEL(Minimum Equipt List) for each multi-engine
aircraft I flew. I don't believe there is such a thing for a part 91 single
engine pilot. In most cases, if something were inoperative, that imposed
limits on your flight, but did not cancel the flight. I would not consider
the failure of a light bulb to be an airworthiness item, unless night flight
was planned.
What if your comm radio was inoperative? Non-airworthy? Many aircraft
have no radio, just like many aircraft have no flaps.
Al G
Old July 11th 07, 12:22 AM posted to rec.aviation.owning,rec.aviation.piloting
Hilton
Default flaps
Al G wrote:
Never the less, it is left to me to decide,
It is up to you to decide *while adhering to the FARs*, I think you're
missing that point.
Hilton
Old July 11th 07, 12:37 AM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default flaps
"Hilton" wrote in message
t...
missing that point.
Hilton
(b) The pilot in command of a civil aircraft is responsible for
determining whether that aircraft is in condition for safe flight. The
pilot in command shall discontinue the flight when unairworthy
mechanical, electrical, or structural conditions occur
Nothing in the "regs" says I have to use flaps in a C172.
Al G
Old July 11th 07, 09:41 PM posted to rec.aviation.owning,rec.aviation.piloting
karl gruber[_1_]
Default flaps
Maybe not, you don't have to USE them..........but they must be operable.
Karl
"Al G" wrote in message
t...
missing that point.
Hilton
Al G
Old July 11th 07, 10:48 PM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default flaps
t...
missing that point.
Hilton
Al G
"karl gruber" wrote in message
Karl
I don't see where that is true.
Hilton helped us with the definition:
a. The aircraft must conform to its TC. Conformity to type design is
considered attained when the aircraft configuration and the components
installed are consistent with the drawings, specifications, and other
data that are part of the TC, which includes any supplemental type
certificate (STC) and field approved alterations incorporated into the
aircraft.
Obviously the 172H was certified to fly without flaps, as that is the normal
operating mode. The G's allowed are higher without flaps, so it must be
safer, right? Many of the tests for certification were done ONLY with flaps
up. This aircraft has no KOEL, nor does the limitations section of the
owners handbook refer to flaps. I can understand the requirement when
operating in a manner that requires them, say over an obstacle. In that case
your "Operations" require them. However, I do not see how operating with
flaps up and un-available violates any portion of the type certificate, and
therefore does not make this aircraft un-airworthy.
If an aircraft is certified VFR/IFR, and a vacuum pump goes south, you can
operate it VFR without a ferry permit, right? The attitude indicator is not
part of VFR certification. Do you need a "Special Certificate" to fly home?
How about the landing light or panel lights during daylight operations? Not
needed, not part of the day VFR certification. Same thing right?
Are you telling me that if you were in Joseph, Oregon, (No mechanics, No
Feds, No help), and
you had a panel light dimmer failure, that you wouldn't fly home and get it
fixed?
This is almost getting to the point where "everything" must work, (zero
tolerance). If I have two navigation lights on each wing, and one of them
burns out, can I fly at night? It sounds awfully unsafe to say I'm going to
go out and fly at night with a known inoperative nav light.
In fact, if this were true, you would cut your dispatch rate by adding the
extra nav light, as that provides one more item to go bad, thereby doubling
the effective "Nav Light Cancellation Rate".
Al G
Old July 12th 07, 12:37 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
Default flaps
On Wed, 11 Jul 2007 14:48:58 -0700, "Al G"
And for a H model where there is aparantly no limitation to the
contrary it likely doesn't. The point here is that at least in the R,
S, and T NAV III 172/182 models there *IS* a specific limitation that
for all intents and purposes requires the flap system be operable. The
point here is that people should check their own aircraft's POH to
make sure they are in compliance with the limitations when they have
inoperative equipment, regardless of what equipment is inop.
If it's not required explicitly in part 91, the next question that
needs an answer is wheter the item is listed as R or S in the KOEL or
eqipment list? If it's listed as required equipment in the KOEL or
equipment list then I postulate that yes, in fact, you either need to
fix it, or you do need a special cert to fly home if that item is
inopearive. It can and has been demonstrated to be different from
range of aircraft to range of aircraft, even in the same generic model
(I.E. Nav II or Nav III equipped 182T), and whatever POH is in that
specific airframe is what's required to be adhered to.
Old July 16th 07, 03:04 PM posted to rec.aviation.owning,rec.aviation.piloting
Default flaps
It's not so simple but it's not complicated either. The
regs detail what needs to be installed and working for any particular
sort of flight (day VFR, night VFR, and so on) and if something is
dead, something like a landing light, it must be snagged in the
logbook and then deferred if you want to keep flying. Determining who
can defer a defect becomes your job. There are things (like fuel
gauges) that have to be working all the time and can't be deferred.
See CAR 605.14 thru 605.41 to see what you need:
http://www.tc.gc.ca/CivilAviation/Re...605.htm#605_14
Then see CAR 605.10 to see how to deal with dead stuff:
http://www.tc.gc.ca/CivilAviation/Re...605.htm#605_10
That pooched landing light isn't necessary here in Canada at
night if you aren't carrying passengers, but I still wouldn't want to
fly without it. I want to see that deer on the runway so I can go
around. Nav lights ARE necessary, as is the anti-collision light. Dead
flaps would be a real debate between the mechanic and pilot, and the
mechanic is going to be conservative because it's his signature on the
line deferring them. As a mechanic, I would get a ferry permit to
avoid the risk of losing my ticket and to avoid putting passengers at
risk. If that engine quits and the pilot has to put the thing down is
an inconvenient spot, those flaps could make the difference between
landing at a survivable speed or getting smashed to bits.
The airplane doesn't have to be perfect. It needs to be
safe for the intended flight.
Dan
Old July 11th 07, 12:26 AM posted to rec.aviation.owning,rec.aviation.piloting
Peter Clark
Default flaps
On Tue, 10 Jul 2007 16:02:51 -0700, "Al G"
KOEL=??
Kinds Of Operations Equipment List. It's contained in Section 2 of
the POH (AKA Operating Limits) and is prefaced:
"The Cessna 182T Nav III airplane is approved for day and night, VFR
and IFR operations. Flight into known-icing conditions is prohibited.
The minimum equipment for approved operatons required under the
Operating Rules are defined by 14 CFR Part 91 and 14 CFR Part 135, as
applicable.
The following Kinds of Operations Equipment List (KOEL) identifies the
equipment required to be operational for airplane airworthiness in the
listed kind of operations."
Basically, the lawyers have set it up so that Nav III aircraft have
stricter limits on what equipment is required than in the older
aircraft that you're used to by creating a KOEL (effectively a MEL).
The way it was explained to me is that just like a MEL, in these ones
(and I'm pretty sure the 172 Nav III has it as well but don't have a
POH or IM handy) since the flap motor and indicator are listed as
required by the table in the limitations section, they have to be
working or you're not in fact airworthy - regardless of the operation.
The POH has effectively removed the decision from you in an aircraft
with a MEL or KOEL.
Old July 11th 07, 12:40 AM posted to rec.aviation.owning,rec.aviation.piloting
Al G[_2_]
Default flaps
they
as
without
KOEL=??
applicable.
with a MEL or KOEL.
So if the flap switch is inop, you're good to go?
Al G
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
Flaps on take-off and landing Mxsmanic Piloting 397 September 22nd 06 09:02 AM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
