On Tue, 10 Jul 2007 16:40:28 -0700, "Al G"
wrote: Basically, the lawyers have set it up so that Nav III aircraft have stricter limits on what equipment is required than in the older aircraft that you're used to by creating a KOEL (effectively a MEL). The way it was explained to me is that just like a MEL, in these ones (and I'm pretty sure the 172 Nav III has it as well but don't have a POH or IM handy) since the flap motor and indicator are listed as required by the table in the limitations section, they have to be working or you're not in fact airworthy - regardless of the operation. The POH has effectively removed the decision from you in an aircraft with a MEL or KOEL. So if the flap switch is inop, you're good to go? If you can somehow prove it's the switch and not the motor without being an A&P and re-rigging the electrical wiring to show the motor and indicator are both working, I guess. The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. |
Peter Clark wrote:
The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Now, you know, and I know, and every body hanging out in the airport coffee shop knows that you can land a 172 with no flaps on a 2000 foot paved runway without any problems (assuming you know what you're doing). But, that doesn't count when it comes to determining if the airplane is airworthy. Remember, airworthy is a state of paperwork, nothing more, nothing less. |
Roy Smith wrote in
: Peter Clark wrote: The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Now, you know, and I know, and every body hanging out in the airport coffee shop knows that you can land a 172 with no flaps on a 2000 foot paved runway without any problems (assuming you know what you're doing). But, that doesn't count when it comes to determining if the airplane is airworthy. Remember, airworthy is a state of paperwork, nothing more, nothing less. The POH for the 1977 C172N Skyhawk (D1082-13-RPC-1000-9/89) has exactly one landing table, on page 5-21, marked "Short Field". This table ONLY shows landing distance based on max weight of 2300 lbs. In Section 4 "Normal Procedures" on page 4-19, under "Normal Landing", the POH states "Normal landing approaches can be made with power-on or power-off with any flap setting desired." An interpretation of 91.103 requiring that you know how much runway you need to land or your not airworthy combined with the information provided in this POH implies that you can never legally land a 1977 C172N uless you are at max weight, doing a short field landing, full flaps, and have the capability of inflight refueling (or some other means of ensuring fuel burn doesn't reduce your weight below max) during the landing! I guess no one has ever landed an airworthy 1977 C172N! -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
"Roy Smith" wrote in message
... Peter Clark wrote: The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Now, you know, and I know, and every body hanging out in the airport coffee shop knows that you can land a 172 with no flaps on a 2000 foot paved runway without any problems (assuming you know what you're doing). But, that doesn't count when it comes to determining if the airplane is airworthy. Remember, airworthy is a state of paperwork, nothing more, nothing less. Since the '60s, '70s, and '80s models showed no flap landing data, and flaps were considered optional this question really boils down to what the POH says for the particular aircraft being flown. Students learning at busy commercial airports almost never used flaps as a normal procedure. Of course we taught recovery from fully developed spins to instructors back then also. Isn't it interesting that some modern aircraft could be considered out-of-service for inop flaps, but only a few years ago they were very optional. I imagine that today a DER or FSDO inspector would have a stroke if we used all 60 degrees we had on the old O-1s or rolled on a wheel landing with them at zero. -- Jim Carter Rogers, Arkansas |
![]() "Roy Smith" wrote in message ... Peter Clark wrote: The intent of the limitation - flaps have to be working - is obvious. They don't say you have to actually use them, but they do have to be in working order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Now, you know, and I know, and every body hanging out in the airport coffee shop knows that you can land a 172 with no flaps on a 2000 foot paved runway without any problems (assuming you know what you're doing). But, that doesn't count when it comes to determining if the airplane is airworthy. Well said Roy. I can see Cessna adding it to the "Operating Limits", after all the charts for that aircraft using specify their use, hence the KOEL. The 1967 172H manual I'm looking at has a single page limitations section, with no mention of flaps. Just the Day/Night/VFR, with instruments, IFR, normal category. The landing chart is a single line assuming short field over an obstacle, with 40 degrees of flap. Remember, airworthy is a state of paperwork, nothing more, nothing less. Interesting concept, what would Orville, Wilbur, or Dudley think? You don't happen to have an "FAA" definition of airworthy do you? Al G |
![]() "Roy Smith" wrote in message order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Well, you certainly haven't seen all the Cessnas POHs. Mine has performance numbers for "SHORT FIELD" only. Normal landings can be conducted with ANY amount of flaps, per the FLAP LIMITATIONS section. Karl |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
