Jay Honeck wrote:
Spend an hour or two landing on the numbers with the stall horn squalling. It's funny how much easier this was to do when I was renting airplanes. Heck, I'd routinely drag it in at minimum forward air speed and plunk it on the numbers, just to see how short I could land. When you own an aircraft -- especially one with a big, heavy 6- cylinder engine that is slightly nose-heavy -- you think twice before "practicing" such things. Tires, struts, brakes, firewalls, props, and engines all become HUGE impediments to "practicing" landings with the stall horn squalling, since you're paying for them all. I believe my 182 had a similarly sized engine to your Piper and I always landed as close to full-stall as I could get. If you do it all the time, then you get to where it works pretty much all the time. And landing this way SAVES on tires and brakes and, done properly, has no affect on struts, firewalls, prop or engine. This post, IMHO, above all else, is a real tribute to the utility of manual, Johnson-bar flap actuators. Hard to miss when THOSE don't work. It is hard to miss Cessna flaps either. I have to admit to wondering where Kobra mind was during that landing. Full flaps in any Cessna I've flown is simply hard to ignore, but I haven't flown a 177. Matt |
![]() It is hard to miss Cessna flaps either. I have to admit to wondering where Kobra mind was during that landing. Full flaps in any Cessna I've flown is simply hard to ignore, but I haven't flown a 177. Matt, Yes, you are correct, when the flaps DO deploy it is noticeable. The flaps on the 177 are large and effective. It's when they DON'T deploy that it can get past you unnoticed in a busy cockpit. How many times have you flow a Cessna that the flaps failed to set? Probably never. So most of the readers here have no idea how they would or wouldn't notice the failure. If I was a CFI I think I might occasionally pull the flap breaker and see how many students catch the situation and at what point. AAMOF I will throw that out there to the CFI's...let's do an experiment. Pull the breaker when the student isn't looking and have them fly the pattern for a landing. Post the results on how many did and didn't understand the problem. If they catch it, at what point did they realize that no flaps were out? I'd be interested in the results. Post the results here under this post "flaps". Kobra |
Kobra wrote:
It is hard to miss Cessna flaps either. I have to admit to wondering where Kobra mind was during that landing. Full flaps in any Cessna I've flown is simply hard to ignore, but I haven't flown a 177. Matt, Yes, you are correct, when the flaps DO deploy it is noticeable. The flaps on the 177 are large and effective. It's when they DON'T deploy that it can get past you unnoticed in a busy cockpit. How many times have you flow a Cessna that the flaps failed to set? Probably never. So most of the readers here have no idea how they would or wouldn't notice the failure. Just once, but I noticed it instantly, and I was already pretty busy flying an instrument approach into OSH of all places after having lost my alternator. When I noticed the alternator light come on about 20 miles out, I turned off everything but one navcomm and the transponder. However, once on short final, the old habit kicked in and I put the flaps down even though I was on battery power alone at that point. The flaps made it about 5 degrees before the battery gave up the ghost completely. I said "crap" and then proceeded to land the airplane. No big deal and it was instantly obvious that the flaps hadn't deployed even with my mind a little preoccupied. Matt |
Matt Whiting wrote:
Just once, but I noticed it instantly, and I was already pretty busy flying an instrument approach into OSH of all places after having lost my alternator. When I noticed the alternator light come on about 20 miles out, I turned off everything but one navcomm and the transponder. However, once on short final, the old habit kicked in and I put the flaps down even though I was on battery power alone at that point. It's amazing how that works, isn't it? Years ago, when I was working on my instrument rating, my instructor and I had just taken off on a night IFR flight and were having trouble checking in with NY Departure. The radio's were scratchy and they weren't getting our xponder, when we noticed the panel lights dim. We told NY we were returning home. On the short flight there, we discussed the idea that we might have enough battery to get the flaps down and not enough to get them back up if we needed to go around. We decided to do a no-flap landing. Exactly the same thing happened that you described -- habit kicked in and without even realizing what I was doing, I reached out and put the first 10 degrees of flaps in on downwind. It's just hard to break the habit. |
![]() Matt Whiting wrote: It is hard to miss Cessna flaps either. I have to admit to wondering where Kobra mind was during that landing. Full flaps in any Cessna I've flown is simply hard to ignore, but I haven't flown a 177. I owned one. You can't miss them if you happen to be in the aircraft during a landing. |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
