flaps
Old July 11th 07, 12:49 AM posted to rec.aviation.owning,rec.aviation.piloting
Blueskies
Default flaps
"kontiki" wrote in message news
Blueskies wrote:
Why are you beating up the plane?
I was taught and used to teach that any landing without full flaps was an 'emergency' landing. The airplane has a
landing configuration and the performance in the book is based on that configuration...
It is good to practice emergency landings every so often.
Beating up my plane? Have you ever flown a Comanche? All you
need is 20 degrees for smooth and graceful landings in a PA24.
If I'm going into a really short field (2000 feet?) then I'll
use full flaps.
All the 182's I've ever flown only need 20 degrees of flap
for nice landings too. Go full flaps and its like an anvil
with a parachute. The 182 is a great short field airplane.
So, what is the expected landing performance for the Comanche, landing with 20° flaps?
Tires and brakes at least are taking more than they need to. Wheel bearings too. Struts and oleos thumping over the
expansion joints, etc...
Always landed the PA32-300 with full flaps, nice and slow. And that was in HI with screwy cross winds pretty much always
blowing 15-20 knots.
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
Flaps on take-off and landing Mxsmanic Piloting 397 September 22nd 06 09:02 AM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
