On Jul 14, 8:55 am, "Dennis Johnson" wrote:
wrote in message ps.com... The temp in the pan is true state of affairs in the engine. While that might be true, I think the benefit of measuring oil temperature as the oil enters the engine is that it enables the engine manufacturer to provide meaningful oil temperature specifications. For my engine, TCM says that the oil entering the engine (after passing through the oil cooler) can be as hot as 240°F at full power and still be acceptable. TCM apparently feels that so long as the oil entering the engine is no hotter than that, then the engine will be fine so long as I'm using a recommended oil. For takeoff, the oil entering the engine should be at least 100°F as it enters the engine. If we measured oil pan temperatures, the engine manufacturer would never know what kind of oil cooler we had or how well the cooler was installed and could not specify a maximum or minimum oil temperature because they wouldn't know how efficient the oil cooler was. Dennis If we/ they didn't measure the temp of the oil as it left the pan the oil manufacturer would have no idea how to formulate the correct viscosity, additives, and anything else needed to make oil perform at a given temp. . In a certified plane the manufacturer knows exactly what kind and how efficient the oil cooler is. They would never honor a warranty if they didn't. Take a Piper, leave on the winterazation [sp] plate that blocks alot of the air feeding the cooler. Fly said plane through death valley when the air temp is 120+f, now take plane to local dealer for a warranty claim for a "cooked" motor and see how fast they laugh you right out of the hangar........ G Ben |
dirty oil | Dan Luke | Owning | 46 | March 15th 07 02:25 PM |
Dirty Laundry | [email protected] | Piloting | 6 | October 18th 06 10:36 PM |
dirty bird | The Weiss Family | Owning | 9 | November 9th 04 05:14 PM |
"Dirty Tricks" and "Both Sides Do It" | Leslie Swartz | Military Aviation | 19 | March 29th 04 06:11 PM |
Vic Tatelman's Pictures of "Dirty Dora", "Dirty Dora II" and the Surrender Mission | Adam Lewis | Military Aviation | 0 | February 3rd 04 03:39 PM |
