![]() Good post Andy, but I believe we need a set penalty to discourage deliberately doing a rolling finish on a good day. I watched a well known pilot make a rolling finish every day for 5 days in a row (1000 feet and 2 mile finish cylinder). I have recommended the rules committee consider the following: up to 100 feet low = 5 point penalty up to 200 feet low = 10 point penalty up to 300 feet low = 15 point penalty up to 400 feet low = 20 point penalty rolling finish = 25 point penalty JJ Should read: For a 4-hour task the 4 points per 100' drops to 2 points per 100'. 9B |
Lots of good points made.
I went flying yesterday and found that my SN10 has a beatiful digital pressure altimeter readout, that is automatically calibrated before takeoff to field elevation, and can be reset inflight to the latest altimeter setting if desired. I also found that my mechanical POS alitmeter lags about 100' during a final glide, showing me that much higher that the SN10's no-friction digital readout. Guess what I'll be using from now on! Back to the original subject (actually a spin off): I still think the current hard cutoff at 500 ft is a poor setup, due to the difficuty for the pilot to accurately judge his altitude at the time of crossing the line. If the goal is to make pilots finish higher (for whatever reason), then there needs to be a finish window the pilot can aim for that if he accurately figures his final glide, will not be penalized. Let's assume we can hit a 200' window - and assume that 300' agl is the cutoff for a safe pattern. Setup the scoring so anywhere in the 200 ft window (300'agl to 500'agl ) is neutral - if below the nominal 500', then add the time it would have taken to climb in (based on the climb rate in the last thermal). That would remove any incentive to finish lower than 500', but give a reasonable window to shoot for before a bigger penalty (automatic rolling finish score) kicks in. Comment? Obvious problems? Kirk 66 |
kirk.stant wrote:
I still think the current hard cutoff at 500 ft is a poor setup, due to the difficuty for the pilot to accurately judge his altitude at the time of crossing the line. If the goal is to make pilots finish higher (for whatever reason), then there needs to be a finish window the pilot can aim for that if he accurately figures his final glide, will not be penalized. Let's assume we can hit a 200' window - and assume that 300' agl is the cutoff for a safe pattern. Setup the scoring so anywhere in the 200 ft window (300'agl to 500'agl ) is neutral - if below the nominal 500', then add the time it would have taken to climb in (based on the climb rate in the last thermal). That would remove any incentive to finish lower than 500', but give a reasonable window to shoot for before a bigger penalty (automatic rolling finish score) kicks in. Comment? Obvious problems? I'd suggest the opposite. I think I should be rewarded for every foot that I have over the minimum finish height of, say, 500' AGL. So, if I finish at 2000' AGL, I should get the actual time I spent climbing the last 1500' deducted from my task time. It's more accurate, and it favors my chosen strategy, what's not to like? 8^) In reality, any halfway decent glide computer, or software with access to pressure altitude, will prior to takeoff either automatically determine the field elevation or let the pilot set it manually. The same sort of problem exists with the start cylinder if one can climb to the top. The glide software I use (which I wrote) automatically determines field elevation just prior to takeoff. It monitors my altitude in the start cylinder, signals me if I climb through the top and does a countdown when I reenter, provides progressive warnings as I approach the hard altitude limit (usually 17500' MSL out here), and automatically adjusts my arrival altitude based on the minimum finish height, all based on that initial field elevation measurement. I'm confident that this will work within a margin of 10 or 20 feet, as it using the pressure altitude that will ultimately show up in the IGC file, and I don't have to pay much attention to any of it. The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? Marc |
On Jul 29, 4:01 pm, Marc Ramsey wrote:
The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. Andy |
Andy wrote:
On Jul 29, 4:01 pm, Marc Ramsey wrote: The SN10 also does a pretty good job at this (mine is better, of course), what's the issue? The issue is that the the altimeter setting is usually unknown at the time of landing but it is almost certainly different for the altimeter setting at takeoff time. The altmeter error on landing, if still using the takeoff altimeter setting, may exceed 100 feet even if there is no significant weather change. SSA competition rules explicitly state that the finish altitude is determined based on the most favorable (to the pilot) of the baselines established at *takeoff*, as well as landing. Guy has verified that Winscore is doing precisely that. If one leaves their glide computer at the takeoff altimeter setting, or the glide software is able to calculate a takeoff pressure altitude baseline and uses that to determine the finish arrival altitude (as mine does), altimeter error is simply not a factor... Marc |
WinScore Question | Ray Lovinggood | Soaring | 2 | June 5th 07 03:15 PM |
calculate last point of diversion | jaws | Piloting | 1 | July 5th 06 04:19 PM |
How to calculate TOC and TOD? | Andrea da lontano | Piloting | 3 | October 21st 04 09:24 PM |
Weight and Balance Formula, Can one calculate the envelope | Joe Wasik | Piloting | 12 | September 29th 04 08:15 AM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
