Electrically Powered Ultralight Aircraft
Old August 17th 07, 04:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Default Electrically Powered Ultralight Aircraft
In rec.aviation.piloting Charles Vincent wrote:
In rec.aviation.piloting Tim Ward wrote:
The advantage from the electric engine at cruise is that it uses zero
energy.
Snippage
Jim Pennino
Remove .spam.sux to reply.
You want to support this, somehow?
Tim Ward
At cruise the electric motor is turned off.
The only energy used is some slight bearing friction.
The electric motor is only turned on when more power than the gas
engine can provide is needed.
To carry more weight at the same speed and altitude takes more power, so
you have to account for the energy expended kiting you deadweight
electric takeoff system around the sky as well. Sizing an engine for
cruise has been done, if only backwards. Think JATO. Most JATO's are
actually RATO (rocket assisted takeoff). I expect RATO would beat an
electric system based on energy density and the fact that when it is
done you have reduced your weight by the fuel. I also suspect for a
given amount of thrust the rocket will be lighter than an electric motor
and associated clutches and gearing. In my opinion, at this point in
time it is just as practical for a homebuilt as well as in not.
Well, that's true enough, but the above was about hybrid cars.
Jim Pennino
  #123
Old August 17th 07, 05:04 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
energy.
Snippage
Jim Pennino
Tim Ward
Well in cruise in a car, more weight does not increase your aerodynamic
drag like it does on an airplane, but it does increase your rolling
resistance in the real world, so there is no free lunch. Different
tradeoffs for different missions. I guess that is why cheetahs and
sparrows look so different.
Charles
  #124
Old August 17th 07, 05:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
No, it's not true enough.
To carry more weight at the same speed and altitude requires more LIFT.
A higher CL - and/or more wing area.
THEN, to overcome the increased drag, THEN you need more power.
But more power by itself won't satisfy the constraints...
So if I add 1 pound to a 2400 pound gross aircraft loaded to 2300 pounds,
it would be impossible to cruise at the same speed and altitude without
the 1 pound unless I added wing area?
How about 50 pounds?
Jim Pennino
  #125
energy.
Snippage
Jim Pennino
Tim Ward
Unless the added weight is enough to deform the tires, the increase
in rolling resistance in the total energy expediture can't be found.
Jim Pennino
  #126
Old August 17th 07, 05:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
so you have to account for the energy expended kiting you
deadweight electric takeoff system around the sky as well. Sizing
an engine for cruise has been done, if only backwards. Think JATO.
Most JATO's are actually RATO (rocket assisted takeoff). I expect
RATO would beat an electric system based on energy density and the
fact that when it is done you have reduced your weight by the fuel.
I also suspect for a given amount of thrust the rocket will be
lighter than an electric motor and associated clutches and gearing.
In my opinion, at this point in time it is just as practical for a
The original remark said "To carry more weight at the same speed and
altitude takes more power" -- which you have now taken the time to
substantiate with more detail. It never said it was the only factor,
and didn't need to, to rebut the earlier claim. I do not understand how
you arrive at it not being true. Frankly, I would expect any one
engaged in building or flying an airplane to understand those
relationships, and based on the FAA's published pilot exam questions and
other materials, it seems they agree.
Charles
  #127
Old August 17th 07, 05:32 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
No. You can increase the angle of attack, which increases the lift ( to
a limit) and also increases the drag, which must be overcome with more
power. If your speed drops, so does the lift. If you could increase
your aspect ratio, you could get more lift at the same speed at the same
power I think. So I guess Richard is flying a swing wing texas
parasol.;') For the rest of us, we have to add power to carry more
weight at the same speed and altitude. Since most planes lose weight
while in flight in the real world, you actually have the opposite issue.
Charles
  #128
Old August 17th 07, 06:20 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Morgans[_2_]
Bull hockey.
Just because it is not noticeable, or measurable by the lack of sensitivity
with the instrument you are currently not using, does not mean that it does
not exist.
More weight on the bearings will cause more rolling resistance. That is
fact, not open to dispute. If you say it is, I want to buy the rights to
the bearings you are using, so I can patent them and make a fortune.
Jim in NC
  #129
Old August 17th 07, 06:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Gee, you mean all I gotta do is tweek the trim and throttle a bit?
Who'd have guessed it? :-)
Jim Pennino
  #130
Old August 17th 07, 07:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Phil
On Aug 15, 8:18 am, Larry Dighera wrote:
On Wed, 15 Aug 2007 12:23:00 GMT, CanalBuilder
wrote in
How much of a fire hazard would a paper battery be?
http://www.energy-daily.com/reports/...oring_Power_In...
That is an interesting device indeed. Given these quotes from the
article:
Rensselaer researchers infused this paper with aligned carbon
nanotubes, which give the device its black color. The nanotubes
act as electrodes and allow the storage devices to conduct
electricity. The device, engineered to function as both a
lithium-ion battery and a supercapacitor, can provide the long,
steady power output comparable to a conventional battery, as well
as a supercapacitor's quick burst of high energy. ...
Along with use in small handheld electronics, the paper batteries'
light weight could make them ideal for use in automobiles,
aircraft, and even boats. The paper also could be molded into
different shapes, such as a car door, which would enable important
new engineering innovations.
IF these can be made practical, they sound ideal for use in an
airplane. They are light, and they can be shaped in just about any
way to fit inside the airframe. Suppose they were integrated into the
airframe and wings such that a large percentage of the airplane
consisted of battery. It might be possible to get enough capacity
there for a practical general aviation electric plane.
Solar powered aircraft. Was: Can Aircraft Be Far Behind? Jim Logajan Piloting 4 February 9th 07 01:11 PM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Is JB Weld electrically conductive? Scott Home Built 14 July 12th 04 11:24 PM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
