Electrically Powered Ultralight Aircraft
Old August 17th 07, 11:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
cavelamb himself[_4_]
Default Electrically Powered Ultralight Aircraft
Dan Luke wrote:
"Charles Vincent" wrote:
Just because it is not noticeable, or measurable by the lack of sensitivity
with the instrument you are currently not using, does not mean that it does
not exist.
More weight on the bearings will cause more rolling resistance. That is
fact, not open to dispute. If you say it is, I want to buy the rights to
the bearings you are using, so I can patent them and make a fortune.
If a bird craps on your windshield, it is more likely to noticeably
influence your aerodynamic drag than rolling resistance.....I took Jim's
"can't be found" to mean lost in the noise. According to SAE studies,
aerodynamic drag accounts for 60% of the resistance that must be overcome
for highway cruise, with tires being 25% and driveline friction making up
the last 15%.
Pardon the intrusion on this interesting discussion, but just how *does* added
weight in a car impose extra load on the powerplant besides via bearing
friction and tire deformation?
Added weight means the powerplant is doing more work to maintain the same
speed; there's no way around it, the laws of physics demand it. So where's
the extra power going?
To accellerate...
Solar powered aircraft. Was: Can Aircraft Be Far Behind? Jim Logajan Piloting 4 February 9th 07 01:11 PM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Is JB Weld electrically conductive? Scott Home Built 14 July 12th 04 11:24 PM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
