Garmin 396 Reception Problems Solved!
Old September 25th 07, 06:30 PM posted to rec.aviation.owning
Paul kgyy
Default Garmin 396 Reception Problems Solved!
I'll report back if this does the trick. Anyone know of a nifty little
"shelf" I can mount in the Cherokee up high? Maybe something sliding
into the windshield trim plastic?
Mike
I used velcro to secure the antenna to the upper left corner of the
plastic sun visor, then ran the wire down inside the window trim.
Old September 26th 07, 12:54 AM posted to rec.aviation.owning
Mike Spera
Mike
O.K. Great idea. 99% of the time, the visor is stowed in the "up"
position. I can mount it on top of the visor in a way that swinging the
visor down just inverts the antenna. Will it work inverted, or sideways?
Thanks,
Mike
Old September 26th 07, 12:56 AM posted to rec.aviation.owning
Ray Andraka
Mike
Thanks,
Mike
Probably not. The antenna is a patch antenna backed up by a metal
ground plane. If you turn it upside down it will not be facing the
satellites, so if it works at all your signals will be very weak.
Sideways it might be OK if the satellite is visible from that side of
the airplane.
Garmin 396 Reception Problems - Latest Observations Mike Spera Owning 9 November 26th 06 01:10 PM
Garmin 396 Reception Problems - Again Mike Spera Owning 7 October 25th 06 12:20 AM
GNS 430 reception problems Kevin Clarke Owning 13 September 9th 06 08:10 PM
GPS Reception Problems with 396 Dan Piloting 16 August 5th 06 04:01 AM
Cambridge 302 problems solved Tuno Soaring 0 July 8th 04 05:36 PM
