Backwash Causes Lift?
Old October 6th 07, 12:32 AM posted to rec.aviation.piloting
Default Backwash Causes Lift?
On Oct 5, 4:42 pm, "Gatt" wrote:
On Oct 3, 8:15 am, Le Chaud Lapin wrote:
Actually I did because every book I read about flying skimped on the
subject. I'm going to hop over to MIT's OpenCourseWare later this
week and download their most basic course on aero/astro. Benoulli's
principle is toss around as if it were facecloth, but I'm getting the
feeling that no one is really doing the physics.
I SWEAR to you guys, somebody sounding conspicuously like him was out here
within the last couple of months refuting Bournoulli and referring to
pressure under the wing, making plywood fly, etc. Sounds awful familiar.
It's familiar because there are many out there who don't
understand or don't agree with the textbooks. Even among experts
there's disagreement. Every so often one of them makes an issue of it.
It's quite normal, especially if they don't use the Google Groups
Search function first to see what the previous arguments have been on
the subject on a particular newsgroup.
It annoys some of us because the same arguments are put forth
repeatedly and we can't figure out why some don't get it. But it's no
different than my classroom, in which every new batch of students
brings the same misunderstandings and doubts and arguments. We were
young once, too, and didn't believe much of what our teachers were
trying to tell us.
Bernoulli said that moving air has a lower pressure than
static air. The air over the top of the wing is moving considerably
faster than that underneath, so it has lower pressure. It's not
rarefaction; it's the increase in dynamic pressure (velocity) that
subtracts from static pressure, the same phenomenon that makes a
turbine engine work so well.
Newton said that for every action there's an equal and
opposite reaction. If you look at the diagrams of airflow here,
http://www.av8n.com/how/htm/airfoils.html
scrolling down to Figure 3.2, you'll see that there's upwash ahead of
the wing as well as downwash behind it. the upwash is generated by the
approaching low pressure area above the wing. As the wing passes, the
upwash is converted to downwash; if this isn't Newton at work, I don't
know what is. Newton would be just another dead guy.
For the average PPL or CPL this should be sufficient. It's true
enough, even if it doesn't give the detail that the physicist would
like. As I said, most pilots have other careers and interests and they
find that Newton and Bernoulli jibe with what they experience in the
air, so they're satisfied. Making textbooks thicker or filling them
with competing theories does nothing but confuse these people.
If a student wants to argue that the physics as presented are
all wrong he should do extensive research and publish a book on the
subject, not argue with pilots who have been trusting their soft pink
bodies to Bernoulli and Newton for decades.
Dan
Old October 6th 07, 07:14 AM posted to rec.aviation.piloting
Le Chaud Lapin
I'd like to first note something since I am newly exposed to this
field:
In electrical engineering, we have our own set of fundamental
principles. The "terminal" set of primitives governing electronics
(electrostatics and electrodynamics) is Maxwells Equations
http://en.wikipedia.org/wiki/Maxwell_equation. [Ironically, during
his lifetime, Maxwell was also someone who was a leading expert on
aerodynamics. The notions of gradients, the Laplacian, and scalar
potentials have strong parallels in both fields.] In EE, we have out
own myths, like power lines causing brain cancer, but when they arise,
the experts work hard to show indisputable evidence, verifiable,
rigorous evidence to the contrary, to nip the non-sense in the bud.
We do still have areas of disputes, like what causes shot noise in
circuits [http://en.wikipedia.org/wiki/Shot_noise], but on the bread-
and-butter basics, you won't find a college-leve textbook speaking
untruth. So naturally I am extremely surprised to see this happening
in aerodynamics. You are, after all, the rocket scientists.
trying to tell us.
Oh, I certainly don't believe what I wrote in the Jeppensen book. I
don't believe what the 3 CFI's told me recently. I don't believe what
my friends friend, the pilot, told me three years ago. And though I
would be highly honored if I could meet him, I don't believe what Rod
Machado, whom I think we would all agree is not exactly dumb nor a bad
teacher, nor ignorant in the field, wrote. I don't believe it for two
reasons:
1. It's obviously wrong if you read and interpret correctly what
Bernoulli wrote.
2. NASA says it's wrong. From Jim Logajan: http://www.grc.nasa.gov/WWW/K-12/airplane/bernnew.html
People are going to yell and boo me for saying this, but after taking
a nice long ride tonight on my motorcyle tonight, I thought the
venturi/Bernoulli thing through, and I am 95% certain that that is not
the reason the pressure is lower. In fact, I could probably provide an
experiment showing you a situation where air is moving considerably
faster on top than it is on the bottom, with much higher presure on
the top. What is ironic is that Bernoulli would still be right, but
the interpretation of Bernoulli would fall apart.
It's not
Not to nit-pick, but dynamic pressure is p(t), where t is time, and
velocity is d/dt R(t), where R is position vector, two totally
different things.
opposite reaction. If you look at the diagrams of airflow here,http://www.av8n.com/how/htm/airfoils.html
Newton did say that. And I looked at that diagram very carefully.
[Thanks for link] The upwash is not casued by an approaching low
pressure. The upwash is caused by a gradient in pressure, going from
high pressure at the leading ede, to low pressure, right above and
slightly-back of the wing, due to rarefication of the wing in motion.
The area above the rarefication is normal atmosphere that has a
propensity to move toward the lower-pressure, rarefied air. The
combination of that normal atmosphere air, combine with the high
velocity of the molecules from the leading edge of the wing, results
in the flow paths (streams) that you see. I haven't looked yet, but I
imagine that there are aerodynamicists, all over the world, who, if
not for appreciation of the hypothesis I am proposing here, have at
least figured this out empircally, and are fretting day and night
trying to find the optimal shape of the leading edge of the wing.
They have two conflicting objectives:
1. Make the shape in such a way so as to minimize drag.
2. Make the shape in such a way so as to increase pressure to impart
high velocity to air molecules moving up/backwards.
I'll be the first to admit that i don't have the capacity to do so at
this moment, but imagine that that one shape of the leading edge is
not appropriate for all speeds of the aircraft. For a given set of
context variables like density, temperature, pressure, angle-of-
attack, airspeed, what-the-plane-was-doing-20-milliseconds-ago,
turbulences...wind, etc...there is an optimal shape for that leading
edge, depending on what you are trying to do. It would be quite wild
if someone were to design a wing that could morph, dynamically by
control of a computer, into an instaneously-optimal shape.
I believe it should be possible to explain a venturi tube, Bernoulli's
principle, and a decent part of why a wing has lift, in about 2-3
pages of written text, with pictures, using no formulas, not even
grade-school mathematics.
I definitely agree a paper should be written, and there should be an
element of rigor, obviously lacking in my posts.
However, I honestly think pilot's have been trusting neither Bernoulli
nor Newton. They are dead. But they each left a legacy, which,
according to the NASA links, have been misinterpreted and abused by
countless theoritsts and educators in this field. So one could say
that the pilots have been trusting these theorists and educators, but
perhaps not even that is the case. I think what Ron hinted at is most-
likely the case, that there is a phenomenon that would allow even a
Neanderthal to achieve technical advancement:
The Neanderthal starts with a contraption that works, and through much
trial-and-error, finds better and better rendentions of that same
contraption. Eventually, he will have something that works so well,
that the question of "Why" would hardly need be asked. Naturally,
theorists will tag along and try to explain with rigorous scientific
principles what he has accomplished with only raw will of spirit, but
the theory does not necessarily have to be right or complete get the
thing in the air. Of course, the Wright Brothers were high-minded
individuals, but I think you get the point.
One might ask, "Well if that is the case, then what is the point of
nit-picking with theory?"
It is because a theory that correctly explains observed phenomenon
generally opens up an entirely new world of order and efficiency.
-Le Chaud Lapin-
Old October 6th 07, 08:26 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Le Chaud Lapin wrote in
ps.com:
it. It's quite normal, especially if they don't use the Google Groups
field:
trying to tell us.
reasons:
Bernoulli wrote.
It's not
different things.
here,http://www.av8n.com/how/htm/airfoils.html scrolling down to
Figure 3.2, you'll see that there's upwash ahead of the wing as well
as downwash behind it. the upwash is generated by the approaching low
pressure area above the wing. As the wing passes, the upwash is
converted to downwash; if this isn't Newton at work, I don't know
true
they find that Newton and Bernoulli jibe with what they experience in
the air, so they're satisfied. Making textbooks thicker or filling
them with competing theories does nothing but confuse these people.
-Le Chaud Lapin-
Wanna make a bet about how long it takes you to get your licence?
Let's have a pool!
I got never!
Bertie
Old October 6th 07, 01:10 PM posted to rec.aviation.piloting
Mxsmanic
Bertie the Bunyip writes:
None of this will influence the time required to get a license.
Old October 6th 07, 06:28 PM posted to rec.aviation.piloting
Mxsmanic wrote in
No fair. you don't get to get into the pool. The horse never bets on
itself.
Bertie
Old October 6th 07, 08:17 PM posted to rec.aviation.piloting
george
On Oct 6, 8:26 pm, Bertie the Bunyip wrote:
Le Chaud Lapin wrote oups.com:
field:
trying to tell us.
reasons:
Bernoulli wrote.
It's not
different things.
here,http://www.av8n.com/how/htm/airfoils.htmlscrolling down to
true
-Le Chaud Lapin-
Let's have a pool!
I got never!
90 hours to solo
Old October 6th 07, 08:28 PM posted to rec.aviation.piloting
george wrote in
ps.com:
oups.com:
Groups Search function first to see what the previous arguments
have been on the subject on a particular newsgroup.
field:
out own myths, like power lines causing brain cancer, but when they
arise, the experts work hard to show indisputable evidence,
verifiable, rigorous evidence to the contrary, to nip the non-sense
in the bud. We do still have areas of disputes, like what causes
shot noise in circuits [http://en.wikipedia.org/wiki/Shot_noise],
but on the bread- and-butter basics, you won't find a college-leve
textbook speaking untruth. So naturally I am extremely surprised to
see this happening in aerodynamics. You are, after all, the rocket
scientists.
forth
no different than my classroom, in which every new batch of
students brings the same misunderstandings and doubts and
arguments. We were young once, too, and didn't believe much of
what our teachers were trying to tell us.
I don't believe what the 3 CFI's told me recently. I don't believe
what my friends friend, the pilot, told me three years ago. And
though I would be highly honored if I could meet him, I don't
believe what Rod Machado, whom I think we would all agree is not
exactly dumb nor a bad teacher, nor ignorant in the field, wrote.
I don't believe it for two reasons:
Bernoulli wrote.
considerably faster than that underneath, so it has lower
pressure.
taking a nice long ride tonight on my motorcyle tonight, I thought
the venturi/Bernoulli thing through, and I am 95% certain that that
is not the reason the pressure is lower. In fact, I could probably
provide an experiment showing you a situation where air is moving
considerably faster on top than it is on the bottom, with much
higher presure on the top. What is ironic is that Bernoulli would
still be right, but the interpretation of Bernoulli would fall
apart.
It's not
different things.
the upwash is converted to downwash; if this isn't Newton at work,
I don't know what is. Newton would be just another dead guy.
from high pressure at the leading ede, to low pressure, right above
and slightly-back of the wing, due to rarefication of the wing in
motion. The area above the rarefication is normal atmosphere that
has a propensity to move toward the lower-pressure, rarefied air.
The combination of that normal atmosphere air, combine with the
high velocity of the molecules from the leading edge of the wing,
results in the flow paths (streams) that you see. I haven't looked
yet, but I imagine that there are aerodynamicists, all over the
world, who, if not for appreciation of the hypothesis I am
proposing here, have at least figured this out empircally, and are
fretting day and night trying to find the optimal shape of the
leading edge of the wing. They have two conflicting objectives:
impart high velocity to air molecules moving up/backwards.
at this moment, but imagine that that one shape of the leading edge
is not appropriate for all speeds of the aircraft. For a given set
of context variables like density, temperature, pressure, angle-of-
leading edge, depending on what you are trying to do. It would be
quite wild if someone were to design a wing that could morph,
dynamically by control of a computer, into an instaneously-optimal
shape.
true
would like. As I said, most pilots have other careers and
interests and they find that Newton and Bernoulli jibe with what
they experience in the air, so they're satisfied. Making textbooks
thicker or filling them with competing theories does nothing but
Bernoulli's principle, and a decent part of why a wing has lift, in
about 2-3 pages of written text, with pictures, using no formulas,
not even grade-school mathematics.
are
the subject, not argue with pilots who have been trusting their
soft pink bodies to Bernoulli and Newton for decades.
an element of rigor, obviously lacking in my posts.
Bernoulli nor Newton. They are dead. But they each left a legacy,
which, according to the NASA links, have been misinterpreted and
abused by countless theoritsts and educators in this field. So one
could say that the pilots have been trusting these theorists and
educators, but perhaps not even that is the case. I think what Ron
hinted at is most- likely the case, that there is a phenomenon that
would allow even a Neanderthal to achieve technical advancement:
much trial-and-error, finds better and better rendentions of that
same contraption. Eventually, he will have something that works so
well, that the question of "Why" would hardly need be asked.
Naturally, theorists will tag along and try to explain with
rigorous scientific principles what he has accomplished with only
raw will of spirit, but the theory does not necessarily have to be
right or complete get the thing in the air. Of course, the Wright
Brothers were high-minded individuals, but I think you get the
point.
-Le Chaud Lapin-
Let's have a pool!
I got never!
90 hours to solo
A control-line model
Bertie
Old October 6th 07, 12:38 PM posted to rec.aviation.piloting
Matt Whiting
Really? Many books still can't agree on the definition of current.
Some say it is the movement of electrons and some say it is the movement
of positive charge and some say it us both. Which is the absolute
truth, Mr. Wizard?
Matt
Mxsmanic
Matt Whiting writes:
truth, Mr. Wizard?
The absolute truth is unknown, and the real proof of wizardry is the ability
to say "I don't know."
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
